I need a tractor.
Discussion in 'Chainsaws and Power Equipment' started by GrJfer, Feb 22, 2022.
  1. Barcroftb
    Barcroftb
    The Mitten
    Yeah sorry saw after I posted that you looked at the Yanmar (essentially a red Deere… kinda sorta) and didn’t like it. Sounds like you’re well on your way to picking the best dealer/tractor for your property. I will be :popcorn: along with everyone else until you make your choice.
    GrJfer, Screwloose, Chvymn99 and 3 others like this.
  2. Yawner
    Yawner
    Louisiana
    Friend of mine has a compact Deere and a limb tore up his hydraulic lines recently. He was mad about where they are located. But I will say that he is rough on equipment.
  3. Screwloose
    So I'm considering a garden tractor basically for mowing a small yard and doing light chores. Has anyone here used a 4 wheel steering deere ? Doesn't seem to be offered in 4wd though and I can't make sense of it as the 4wd already steers in the front. And I want the diesel.
    My current yandeere is 14 years old and other than fluids and general maintenance all that I've replaced is the battery at 10 years.
    I would consider a Kubota diesel if it had any major advantage over the deere. They are quite a distance away though. Also been going to the same family deere dealer for over 40 years and they always seem honest.
    I have a few vintage garden tractors that I am not finding the time to play with and I'll probably sell them off for some funding and space.
  4. sirbuildalot
    sirbuildalot
    Mass
    I agree with the sentiments so far. It depends on your property size and usage. I have a heavily wooded 21 acres so I knew I wanted a decent sized machine. My Kioti NX4510 is 45 hp and lifts 2761 lbs 9 feet in the air. It’s comparable to a big L or a small M Kubota. For a 5 acre and under parcel you could likely get away with a Kioti CK or Kubota small L/big B class machine.
  5. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    This is exactly what we are complaining about on the hydraulic lines for loaders
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Those would be ripped off in the first day or two in my possession lol !
  7. Jack Straw
    Jack Straw
    You gotta get on your knees to remove those connections! What a pain!
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Thats a pain! No thanks !!
  9. Screwloose
    Well that is a rather vulnerable location I do agree.
    I bet a lot of people snag them.
  10. Jack Straw
    Jack Straw
    I know I would :picard:
  11. Gasifier
  12. Gasifier
    I wasn’t thinking of the Arkansas location thingy. :whistle:
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Screwloose, GrJfer and amateur cutter like this.
  14. amateur cutter
    Likely to steer way better with the blower on the 3 point.
  15. Ridgeviewfarm
    Ridgeviewfarm
    up state ny
    In my opinion i would look at a kubota l2501. For the work you want to do it is a great size, i would not get a compact. Or another brand tractor in that size class .Do not go to small.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    The L2501 IS a compact tractor.
    Smaller..like the bx..are sub compact
    GrJfer likes this.
  17. Gasifier
    eatonpcat, GrJfer and HoneyFuzz like this.
  18. GrJfer
    GrJfer
    The Woods of Arkansas
    yooperdave, HoneyFuzz and Gasifier like this.
  19. GrJfer
    GrJfer
    eatonpcat, Chvymn99 and HoneyFuzz like this.
