Project 262
Discussion in 'Chainsaws and Power Equipment' started by Chud, Feb 23, 2022.
  1. Chud
    Chud
    Replacing rotting rubber pieces. There’s a smorgasbord of different bolts on this. Hex, torx and flat. Discovering more bad plastic stuff. I thought I had everything I needed
  2. Chud
    Chud
    This is the bushing I was initially after
  3. Chud
    Chud
    Old and new
  4. LordOfTheFlies
    LordOfTheFlies
    NY
    It's always like that, isn't it?? :D
    What else you gonna replace?
  5. Chud
    Chud
    A dang crack in it
    That’s the kind of stuff you find under the muck
  6. Chud
    Chud
    Oem filter hopefully these are easier on than china filters
    50x easier wow I’ll never use a china filter again
  7. M2theB
    M2theB
    Central Massachusetts
    Youch
  8. Chud
    Chud
    The tank was easy to get off and back on. I didn’t have to remove the throttle, or choke linkage or any of the intake to replace the fuel line so that was easy. The collar seal was in 2 pieces, so gotta get that and start looking for a tank.
  9. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Looks like a couple tanks for sale on eBay tonight
  10. Chud
    Chud
    Thanks, I’ll probably check the salvage trailer at the place where I bought it to see if I can get a parts saw.
  11. T.Jeff Veal
    Good luck
    HoneyFuzz, M2theB and Chud like this.
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Looks like a great project ! I replaced all the rubber parts on a couple Husqvarna 257's. Very satisfying! Keep up the good work !
    T.Jeff Veal, Sandhillbilly and Chud like this.
  13. Chud
    Chud
    Fresh collar seal. This was by far the easiest Husqvarna intake to reinstall. The collar seal held the intake block snuggly in place, so I just had to place the carb and plastic intake in front and slide in the bolts, or maybe I’ve done so many now it’s second nature.:rofl: :lol:
    Husqvarna… we make you become a chainsaw mechanic
  14. Chud
    Chud
    Does anyone know what the little horn on the right side of the collar is for?
    T.Jeff Veal likes this.
