Base plate addition
Discussion in 'Chainsaws and Power Equipment' started by JDT, Feb 16, 2022.
  1. Yawner
    Yawner
    Louisiana
    Do
    Do what he did. Which is 1% of the time. Because if it's a huge round I probably halved or quartered it to keep from wrestling it.
  2. Yawner
    Yawner
    Louisiana
    But I split decent size rounds from my sitting position.
    amateur cutter and T.Jeff Veal like this.
  3. The Wood Wolverine
    If that works for you, that's all that matters. It's not for me, and yes I've tried it more than once. Last time was thee last time. :thumbs::handshake:
  4. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    I like that idea. I think I will make one. It seems that the rounds will be easier to move around on nice smooth rounded steel rather than digging into the dirt. I'm going to make mine with a little cutout around the existing base plate so the round will totally be supported by the new base plate. My hats off to you sir.
    p.s.- I also use knee pads when splitting vertical-much easier on the knees.
  5. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I used a piece of pressure treated 2x12 as a “porch” for mine for a long time.
