What's too hot?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Stihl Kicking, Feb 15, 2022.
  1. Stihl Kicking
    Stihl Kicking
    Missouri
    When we installed this stove, I was on the edge of my seat when the temps touched the red zone on my stove top thermometer. With experience, I've learned to settle down and not stress out so easily. I try not to let it get this high, about 750 degrees, but on rare occasions it does. By the time it reaches this temp, I've usually choked off the air. One thing I've learned, stoves have a lag time on the temps. I'm not sure how accurate this thermometer is, but at least it's a bench mark. The stove seems to handle it well, it's not glowing or popping too much.
    I'm wondering if I'm getting too comfortable with this high of a temperature?
  2. Slocum
    Slocum
    North Central Indiana
    Do you have a inferred heat gun? I’d check your stt with something else to check your temp gauge
  3. TurboDiesel
    I hope your thermometer is off by 100 °
  4. Stihl Kicking
    Stihl Kicking
    Missouri
    I do have one. That is a good idea. :yes:
  5. Stihl Kicking
    Stihl Kicking
    Missouri
    That's answering my question. :yes:That's where the infrared will help.
  6. Horkn
    When the thermometer is room temp what temp does it read?
  7. Stihl Kicking
    Stihl Kicking
    Missouri
    Good question. I'm not sure, it's been a while since it's been room temp. I'll have to remember to check that out. :salute:
    Backwoods Savage and Camber like this.
  8. JimBear
    JimBear
    Do you have a flue probe thermometer also ?
    I called SBI to inquire about stovetop temps & flue temps for my stove, the tech I talked to said sustained 800* stovetop was not an issue. I usually run mine about 650* but it hits 750* occasionally but it usually settles back in about 600*-650*
    The infrared thermometer is a good plan, my magnetic thermometers are off a bit. One is 50* off, the other is 75* off.
  9. brenndatomu
    Same here...my SBI stove couldn't care less about 800* STT...
  10. Stihl Kicking
    Stihl Kicking
    Missouri
    I do have a flue guard, it was right at 800* at the same time.
    Sounds like our stove temps cruise in the 600-650 zone. On the occasions mine hits 750*, I really don't feel like it's out of control, but I do encourage it down.
    brenndatomu and Backwoods Savage like this.
  11. Backwoods Savage
    When wondering how hot, also realize it matters; steel, cast or stone.
    Stihl Kicking, RGrant and brenndatomu like this.
  12. Stihl Kicking
    Stihl Kicking
    Missouri
    I've only had this stove, and didn't know it matters on type of material. How does my steel stove play into this, and the others as well? :confused:
    Buzz Benton and Backwoods Savage like this.
  13. brenndatomu
    Steel will take the most abuse...
  14. Stihl Kicking
    Stihl Kicking
    Missouri
    That's good to know. I'm not pushing for that high of a temp, but at least it makes me feel better about it when it does. No need to change my habits on this one. :salute:
  15. The Wood Wolverine
    700 is my number, but I typically always keep it below 5. If I burn that hot, my living space temps would be 78 and above down to about single digits outside.
  16. Backwoods Savage
    Yes, steel, then cast then soapstone but most say cast and soapstone are about the same. I think they are.
  17. Backwoods Savage
    I'd burn it hotter then and get that house comfy! :whistle:
  18. The Wood Wolverine
    @ 78, I'm cracking windows! :dennis:
  19. Stihl Kicking
    Stihl Kicking
    Missouri
    We like it toasty, mid 80's is comfortable. Fortunately my wife and I agree on that. If I see her pull the throw blanket over, I know the fire needs more fuel..
    Backwoods Savage and theburtman like this.
  20. RGrant
    RGrant
    Connecticut
    I typed this a few times and deleted it not wording what I wanted to say the right way- but here it goes anyhow-
    The metal thermometer I have on the top of my stove, like stihl kicking has disagrees by as much as 150F with my IR gun thermometer.
    Example- my stove top this morning with the metal thermometer was reading about 700F and the IR was telling mid 550s/ low 560s depending where I was pointing on the stove top.
    Felt like a little bit of data overload but your real temp might not actually be north of 700.
