Kentucky Ice storm tree 2022
Discussion in 'The Wood Pile' started by justcrockett, Feb 13, 2022.
  1. justcrockett
    justcrockett
    Cut a slice of the second one.[​IMG]
    Sent from my SM-G781U using Tapatalk
  2. Chud
    Chud
    Sticking with my first answer.
  3. JimBear
    JimBear
    If it’s not punky snag it, it’s already partially split = less labor. The sapwood on oak will sometimes go punky but the heartwood will still be good.
  4. justcrockett
    justcrockett
    If that's an elm I may pass. It's in a pretty bad spot. If it's hickory I'm going for it. [​IMG]
  5. JimBear
    JimBear
    That looks like Shagbark to me but I have been mistaken before.
  6. Stihl Kicking
    Stihl Kicking
    Missouri
    Looking at the bark in the pic with the slice, I'm thinking hickory, but you'll know when you go to split it. The outer edge looks punky, but it looks pretty solid inside. On the oak, with it being split, it has a head start on seasoning. But I'd be careful with that one, it could be under tension.
    Chazsbetterhalf, Horkn and Chvymn99 like this.
  7. Chud
    Chud
    Can you knock the bark off. I promise it will split easy if the bark is in the peeling off stage. If it’s Hickory than you have really good firewood.
  8. justcrockett
    justcrockett
    Peeled bark. [​IMG][​IMG]
    Buzz Benton, Chazsbetterhalf and Chud like this.
  9. Chud
    Chud
    You’ve got a nice patch of firewood to split. :yes:
  10. Horkn
    Some of those pieces sure don't look like any black walnut that we have here, bark wise at least. Others do. Are there a couple different trees that you are showing?
  11. Eckie
    Eckie
    It's hickory, and solid enough. I'd get it soon though.
  12. Horkn
    Yep. Definitely hickory of some sort
  13. buZZsaw BRAD
    Thats pignut hickory and the meat is still good. Grab that first and split :axe:it before it gets too warm and fungi/bugs can get it. Agree with prior posts about the oak.
  14. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Sh
    Hickory for sure either shagbark or pignut. In any event get it all...
    Welcome to the land of woodenheads! I'm up in Boone County, Kentucky myself. Drop in if ya get up our way! :salute:
  15. justcrockett
    justcrockett
    Stringy [​IMG]
  16. Stihl Kicking
    Stihl Kicking
    Missouri
    Looks like good wood. :yes: Hickory can be stringy, and that's partially seasoned, which can make it stringier.
    Chazsbetterhalf and justcrockett like this.
  17. buZZsaw BRAD
    Some nice splits there!
  18. justcrockett
    justcrockett
    Good on the partially seasoned. Moisture meter says 32 percent. Hopefully good by next winter.....
    Chazsbetterhalf likes this.
  19. justcrockett
    justcrockett
    Got the ole lady out for alittle while. 028 AV. It was the first saw I ever ran and it still runs like a top.[​IMG]
    Chazsbetterhalf and buZZsaw BRAD like this.
  20. buZZsaw BRAD
    My first "real" saw was an 028 super given to me new in 1985 when i was 17. Accidentally ruined by running on raw gas years later.
    Bought a used one a couple years ago in memory of my late uncle who gave it to me. Run it every couple months. Fond cutting memories.
    Here's a good link about the 028.
