Leak detectors that shut of water supply
Discussion in 'The DIY Room' started by Jack Straw, Feb 13, 2022.
  1. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    My friend’s basement flooded due to a leaky valve. I would like to install a valve that shuts off the supply water to the house if a leak is detected. They have wireless sensors you can place in your basement. I need one for my basement as well. Has anyone had any experience with these? Maybe TurboDiesel?
    Thank you folks! :thumbs:
  2. Warner
    Following. I used to shut the well pump off when we left for extended periods. Now we have chickens and I leave it on for the neighbor kid to water them.
  3. Jack Straw
    Jack Straw
    I do the same thing. There may be enough water for the chickens in the system with the pump off, or maybe store water in a pail for the chickens?
  4. Earl764
    Earl764
    CT
    You can use zwave for this. Some water sensors trip, and that triggers an event that turns off a zwave enabled valve you plumb in.
    TurboDiesel and Screwloose like this.
  5. brenndatomu
    With any of these leak protection valves, whether they are electronic, or spring loaded mecanical valves, they need to be exercised if they are expected to do their job when/if the times comes...if they sit there for years without moving, they won't do their job when needed...stuck, solid...or just won't seal shut if it does move.
  6. Screwloose
    This should be done on every valve you can find. Especially the valves behind toilets and under sinks ect. You might just find them stuck.
    Warner, M2theB, eatonpcat and 3 others like this.
  7. TurboDiesel
    My neighbor has one.
    And we put a leak sensor at the church after the last big flood. (It will call me and the pastor)
    I'll get some info gathered ...
  8. TurboDiesel
    This is a well monitor that i heard about recently. (It's more for protecting the well pump from high amp and run dry, rapid starts)
  9. brenndatomu
    :binoculars:
  10. TurboDiesel
    Neighbor has Yolink water detection.
    Shuts off the well breaker power
  11. brenndatomu
    Definitely
  12. TurboDiesel
    This moen brand looks pricey, but it will send you alerts and allow you to turn the water off remotely through a cell fone app
    Screwloose and brenndatomu like this.
  13. Screwloose
    Handy way to curb teenager 1/2 hour showers.
  14. Chris F
    Chris F
    Micksburg, Ontario
    I use the graph from my real time electricity monitor to shame her. Compare how long the water heater has to run after her shower to mine and the wife's.
    The guilt doesn't last too long though.
    The water heater after her shower is at the 1500 hr mark.
  15. MasterMech
    You and the wife showering together (To save energy .... right?) just might be what got you into this mess! ;):rofl: :lol:
    Jack Straw, Chris F and brenndatomu like this.
  16. Chris F
    Chris F
    Micksburg, Ontario
    LOL!
    I mean compared to my shower and my wife's shower.
    Jack Straw likes this.
