Quality wood shed plans?
Discussion in 'The Wood Pile' started by makey98, Feb 13, 2022.
  1. makey98
    makey98
    Anyone have a source or recommendation for large wood shed plans? I am just thinking about a simple large shed with just a gravel/stone floor and no sides or just a couple slatted boards for sides. Holding lots of wood and some other junk so maybe 8x 20? 10x20? I am not talented or experienced at building stuff so was trying to find some plans to follow. The plans I have seen were 80-130 bucks!!!
    M2theB, Horkn, gwoods71 and 9 others like this.
  2. ReelFaster
    ReelFaster
    S.Jersey
    I don't have plans but I used these for inspiration. Mine is 20x16deep 20210803_165826 (1).jpg 169787313.ZceW49Yc.jpg image.jpg IMG_20190226_24435.jpg Woodshed02.jpg IMG_7181.JPG Shed.jpg
  3. Rickyblazin
    Rickyblazin
    Pottstown PA
    Horkn, gwoods71, ReelFaster and 11 others like this.
  4. makey98
    makey98
    Those are helpful, exactly what I have in mind. Just not sure what size and length posts and then exactly how to do the roof. Winging it never seems to work out for me….
    M2theB, Horkn, gwoods71 and 8 others like this.
  5. Va Homesteader
    Va Homesteader
    Central Va
    setting the post for a pole building will be a real learning experience. to set the post in the exact spot needed I use batter boards . look up batter boards for a start .
    Horkn, gwoods71, ReelFaster and 5 others like this.
  6. Timberdog
    Timberdog
    Az
    You don’t need someone else’s plans. Just come up with your own. If you want ideas google woodshed images. Lots of ideas there.
    Horkn, gwoods71, T.Jeff Veal and 6 others like this.
  7. PatrickNY
    PatrickNY
    Putnam County, NY
    These plans call for 12’ x 3.5’. I used these plans, but made mine 16’ x 5’. A6AEF29B-A2C1-4077-BEC2-6C4903B87C75.jpeg 97194620-2C99-4DC4-91A9-2D7AFE75E5BF.jpeg 226F33BB-9F07-453F-B4F9-0B76AF3CA47A.jpeg
  8. buZZsaw BRAD
    I built this Fall of 2019 out of discounted/cull/reclaimed materials for a friend. 4'x 36' High enough off the ground to ease the back. 6'6" to bottom of beam for head clearance. 3' clearance in back for mowing and access to rotate wood. Here's the thread for the build.
    Lean to Build for a Friend
    WinonaRail, Timberdog, Horkn and 14 others like this.
  9. Yawner
    Yawner
    Louisiana
    Pinterest has countless examples u could check out.
    Timberdog, Horkn, gwoods71 and 5 others like this.
  10. Chazsbetterhalf
    Chazsbetterhalf
    Horkn, gwoods71, T.Jeff Veal and 4 others like this.
  11. jo191145
    When I was a kid we still had a corn crib on the property. Something like this with slanted walls to keep driving rain off. If I were to build one I’d do something like this, just because, nostalgia.
  12. Rickyblazin
    Rickyblazin
    Pottstown PA
    That would be really cool i like that style with slanted walls
  13. buZZsaw BRAD
    ...but then the stacks would be slanted too! :D :rofl: :lol:
  14. TurboDiesel
    So they shouldn't fall over:yes:
    :D
  15. jo191145
    I’d make it a lot bigger and just toss it in dude. You should know me better than that LOL
  16. yooperdave
  17. T.Jeff Veal
    Don't have plans, as I've built many things before. The easiest and cheapest way to build a wood shed is with pallets.
    This shed is 11x15x8. Floor is 2 equipment skids, 7.5x11. Base is 4" cap block and 4x4x15 0525202137.jpg 0526201929.jpg 0527202213.jpg 0528202238a_HDR.jpg
    We spaced the boards evenly and then added 2x6x16 to finish floor 0529201956.jpg
    Used 2x6's spaced to fit notches on pallets 0609201248.jpg 0609201618.jpg 0619201322.jpg
    We named it the calico shed...:rofl: :lol:...
    Roof is left over panels and screws from other jobs we have done. Briwn and green panels with blue screws 0703201240.jpg
    Added some short panels around the outside bottom, keeps rain splash off pallets. 0706201151.jpg
  18. ReelFaster
    ReelFaster
    S.Jersey
    There is a fellow hoarder that did one and shared his whole process as he went along. In fact his is 2nd to last in the pictures I shared with the small lean to with the riding mower under it. I swore I PM'd him at some point to ask him a question but I can't seem to find it, his screen name or his thread. If I do I will surely post, it was helpful.
    I hear you on winging it, depends on the kind of person you are. I am not patient, unless something has to be absolutely precise or I haven't a clue what am doing I'll follow plans. But for a wood shed like this just holding firewood and couple of other things I knew I had lots of room for error. It didn't need to be perfect and as anal as I am on certain things I've learned to let go on some things not being 100% perfect especially something like this out back. Just knowing I did that alone is a pretty dam good feeling.
    I plan on putting sliding barn doors on the middle 10ft wide bay so I can lock it.
  19. Stinny
    Here's my 10'x20' shed roof build... starting with layout of the roof angle...
    12" OC 2x3 boards (not strapping) across 2x4 rafters 16" OC. Double 2x6 carriers front and rear (install 2nd carrier, front & rear, after roof is done... easier) Screw down metal roofing. It'll come to you in 3' wide sections that overlap... at the length you order. I added an inch overlap front and rear. I used a lot of screws to prevent wind rip off... though now that I look at it, the weight of the screws alone might have been enough... :picard::D
  20. gwoods71
    gwoods71
    The Mitten
    I am using an old portable 6'x10' Turkey coop. 2x4 stud walls with 2x4 fencing inside. Set it on pallets and stack it to the ceiling. I figure when it rots out, I will use the steel roof and build another in 5-10 years
    Stinny, Sandhillbilly, Horkn and 2 others like this.
