Who uses a marking stick?
Discussion in 'The Wood Pile' started by Yawner, Jan 2, 2022.
  1. Barcroftb
    Barcroftb
    The Mitten
    you can do it both ways. It tucks in nicely between most saws bar and felling dogs, or you can mark first then remove and buck.
    Personally I use it on a small limbing saw. I start at the base of the trunk and mark rounds out until I get to the limbs. Then I remove it limb the tree out. Then I switch to a bigger saw and cut everything else.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    This is how I use the stick:
    1. I stick it perpendicular to the bar. So if I'm on the left side of the log that is down, I stick the stick to the left of the bar.
    2. Then I put the washer and catch the end of the log, then I just cut a notch in the log at 16".
    3. Next I shift to my right, stick the washer into the cut I just made, and make the next cut, and so on and so forth down the line until I'm done.
    I do not put the stick parallel to the bar ever and once I'm done marking the log and ready to cut, then I take it off and buck away.
    Stephiedoll, Barcroftb and metalcuttr like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    Never said I put it parallel to the bar. The magnet tucks in between the bar and felling spikes if you want to leave it on while you buck a log. Stick is still perpendicular. :yes:
  4. Firewood Bandit
    Firewood Bandit
    I do end up with a few real shorts, 4-6" range. I throw them in the truck and when split those go on top of the stacks and are bonus for people buying quantities. An 8-9" round when split will make a facsimile of a regular split, just put two together when stacking.
    Sometimes the shorts get chucked in the wood with other uglies.
  5. Rickyblazin
    Rickyblazin
    Pottstown PA
    I give up on using rusto marking paint after having get all over everything every time i used it
    metalcuttr and farmer steve like this.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    Ah ha! I thought you misunderstood me.......but it turns out *I* misunderstood *you*! My apologies. Thanks for clearing that up.
    Barcroftb likes this.
  7. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Here's what I use. It's a t handle with a bingo dabber hose clamped onto one end. My stick is 16" and I just walk down the log marking dots and then let er' rip. Fast and cheap. Non-toxic. IMG_1340.jpg
  8. buZZsaw BRAD
    Thats rather ingenious! Nifty invention! :thumbs:
  9. Yawner
    Yawner
    Louisiana
    Hahahahahaha, you are too much, that wins the prize! Luv it!
    buZZsaw BRAD likes this.
  10. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Woods BINGO!
    Yawner likes this.
  11. Dstrick
    Dstrick
    Maple Valley, Washington
    Mingo Marker with water based chalk paint, bar marks, tape measure with marker, calibrated stick.
  12. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    That's awesome! Very cool design
  13. MikeInMa
    16" in length. :thumbs:
    Husqvarna 12" tongs
    The Wood Wolverine and Barcroftb like this.
