What kind of chain is this?
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Fellin', Feb 8, 2022.
  1. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    So I finished working on a donated Mac 160S that had been sitting for 8 years.....with the gas left in it. After rebuilding the carb and replacing the gas line, she runs great. Decided to sharpen her and then it struck me. I have never seen a chain like this before. Its like long rackers or something. Cant find anything about it because I dont know what its called:loco: :crazy: Any help from you "wiser" gentlemen would be greatly appreciated.
  2. Chud
    Chud
    It looks like an early version of safety chain. I’d hate to have to file those extra drags.
    metalcuttr, M2theB, HoneyFuzz and 6 others like this.
  3. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    I couldn't see that there was anything to file? I just sharpened it as normal, but whatever those are has me stumped:faint:
    metalcuttr, M2theB, HoneyFuzz and 3 others like this.
  4. Chud
    Chud
    Eventually that extra vertical plate between the cutter links will be the same height as the raker, but maybe the tooth life will be mostly used up before that happens.
    metalcuttr, M2theB, HoneyFuzz and 4 others like this.
  5. buzz-saw
    buzz-saw
    Ct.
    I think I agree with this.
    Isn't the extra hump there so when the chain rolls around the nose of the bar the hump sticks out past the height of the cutting tooth preventing kickback? Could be wrong but look at the nose of the bar from the side.
  6. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    That makes sense. First I have ever seen, and you are correct Chud, those will be a pain to file down. I plan on using it more for a starter saw for my youngest. Thanx ya'll
  7. JB Sawman
    JB Sawman
    pennsylvania
    That is oregon chain reduced kickback I do not remember the number I will find out they also made it in full size 3/8 it was popular with oem for homeowner saws late 70' it came out it was still sold on poulans ,craftsmans and pole saws etc up in to the 2000's I have not seen it in a while JB
  8. SimonHS
    SimonHS
    Yorkshire, England
  9. Nixon
    Nixon
    West Sunbury,Pa .
    I hate grinding that more than even their old Vanguard chain . Setting the depth gauges is not near as easy and straight forward as with conventional rakers .
    metalcuttr, OldJack, M2theB and 7 others like this.
  10. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    I don't plan on using it much, but guess if it gets too bad, I will upgrade to a newer style. Thanx again ya'll
  11. JB Sawman
    JB Sawman
    pennsylvania
    75 V vanguard chain is miserable after the first couple of sharpening's I agree !! JB
  12. Nixon
    Nixon
    West Sunbury,Pa .
    It’s not bad chain . It’s the rakers that make it tough to deal with . Get a raker gauge and file ,and learn to make it work . After that ,you should be good with any 3/8 lp chain / raker setup .
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    If I was keeping that saw....id pitch that chain....just because!! Lol.
  14. The Wood Wolverine
    Me too. Or offer it up on here for free.
  15. The Wood Wolverine
    I dremel off the bent over portion and use it for sacrificial/stumping chain.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Now that's a great idea !
  17. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Another great idea !
    metalcuttr and M2theB like this.
  18. OldJack
    OldJack
    Saskatchewan, Canada
    I had a loop of that 91 low profile on my John Deere 40V years ago. It was OK when new, but nobody out here on the Prairies knew how to sharpen it. I think we called it fishback chain.
  19. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    That may be the route I go:p
    metalcuttr, HoneyFuzz and OldJack like this.
  20. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Now that s a good idea, a stump chain:yes:
