Different kind of wood bin
Discussion in 'The Wood Pile' started by Creekin, Feb 5, 2022.
  1. Creekin
    Creekin
    Manitoba
    So i was talking to a farmer friend of mine about firewood and such the other day, and he mentioned years ago he had been at a yard where the owner heated with wood. What that guy had done was take a fairly large flat bottom grain bin, cut a large door into it and stacked it full with wood
    Apparently got incredibly hot in there in the summer and dried out his supply very well
    My friend says i should do the same, he knows of a few free bins available, just have to haul home
    Was thinking it should work, has a vent up top, aeration fan on the bottom, i have plenty of space
    What do you guys think? Know of anyone who does similar?
  2. TurboDiesel
    My fatmer buddy built a pavilion out of a grain bin. Lol
    I'll get a pic..
  3. Yawner
    Yawner
    Louisiana
    I can't pull up a pic in my mind of a grain bin you can haul home. Unless you're talking about dismantling one.
    They do get hot in there but they have reflective silver color, so, painting it black would help with temp.
  4. Theashhole
    Theashhole
    Osceola, In
    I've seen a few bins made from some type of fence or grate material with the same type of lid, I think they dried out whole corn cobs in them. Anyway...I think they stopped using them for that and started using them for firewood sounds like a great plan I can't imagine how many cord one will hold
    Sent from my SM-G950U using Tapatalk
  5. TurboDiesel
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I have thought about this many times, and haven’t come up with a reason it would not work
  7. Screwloose
    Sounds ok until you get to the fan. Aeration fans are rather noisy do to the high speed needed to develop the static pressure needed to penetrate grain. This should not be needed with firewood as a thermosiphon should be easy to develop.
  8. Creekin
    Creekin
    Manitoba
    If you have ever shoveled grain in one at high summer temps, you are very thankful for the grain vac !!!!!!
  9. Creekin
    Creekin
    Manitoba
  10. Creekin
    Creekin
    Manitoba
    Very much what i was thinking, no power needed which would be great
  11. JimBear
    JimBear
    I used an empty grain bin to start the drying process on some boards I milled. April - October. Yes, it gets very hot inside those oversized steel cans in the summer.
    I am not sure I would want to run the fan just to dry firewood. Depending on the type & size of the fan you will most likely be paying $5 - $25 a day to run it.
    I have often pondered the same thought but vacant unused grain bins are pretty rare around here.
    An 18’ dia. bin would be about right. I would want to remove a few rings to get to a 6’-7’ interior eve height.
  12. Creekin
    Creekin
    Manitoba
    I'm going to find out some more details from my buddy, would most likely be a spring project
    Definitely take some pictures if it does happen and keep you guys posted!
  13. Backwoods Savage
    Yes.
  14. Screwloose
    A large old fashioned rooftop wind turbine would be beneficial.
    Then there's plenty of solar powered attic fans to choose from. As fans are more efficient pushing air putting them in place of bin fans on the bottom could help.
    Creekin, Buzz Benton and Redneckchevy like this.
  15. Sandhillbilly
    Sandhillbilly
    I know where on is coming up for sale on an online auction. 14’ diameter I believe. The bottom ring is buckled some and would probably need removed which would probably lead to having to modify/adjust the door height if the bottom ring was deleted. Not sure if that would be necessary or not for storing wood. It’s located in south east South Dakota. Near Sioux Falls, that’s about 5 hours from me. needs removed by September I think.
    If someone else is interested, send me a PM and I’ll try and send you the link.
    about 70 miles away in north Platte there’s is one of those drive up coffee shops made out of two bins joined together. Called the Coffee Bin I think.
  16. JimBear
    JimBear
    That would be over by Dakota Hoarder would it not ?
  17. Sandhillbilly
    Sandhillbilly
    Probably fairly close I think
    Screwloose likes this.
  18. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    That would be right by me. There’re using retired grain bins for a lot of things around here. Most interesting are the two story cabins .
