Coming unscrewed
Discussion in 'The Wood Pile' started by Stihl Kicking, Jan 28, 2022.
  1. Stihl Kicking
    Stihl Kicking
    Missouri
    Not sure what category this goes in, but here it is.
    My wife picked up an old ash rake at a garage sale. It's brass and has seen it's days, but is still very useful. Unfortunately the rake screws to the handle and it is constantly comes loose. I'm wanting to permanently secure it. Would stove gasket cement work, but would it stand up to the constant heating and cooling? Although considerably more work, how about a set screw? Something else?
    It drives me crazy, in an OCD way... :hair:
  2. Slocum
    Slocum
    North Central Indiana
    I would try red loctite
  3. Chud
    Chud
    I’ve got a poker that I always have to tighten the handle and tip on. Thanks for the gasket cement idea. There are 2 tubes of it near the poker and I keep mindlessly tightening both ends.
  4. wildwest
  5. Stihl Kicking
    Stihl Kicking
    Missouri
    Red loctite, that's a good idea. I think I have some on hand.
  6. Stihl Kicking
    Stihl Kicking
    Missouri
    LOL, mine comes loose from both ends as well. "Mindlessly tightening both ends", describes it well.
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    A friend of mine spot welded mine for me. Maybe you could braze it.
  8. Slocum
    Slocum
    Clean the best you can before you put it on and don’t be shy with it. You can wipe off excess if it runs out when you thread it in. Give it plenty of time to set up.
  9. Stihl Kicking
    Stihl Kicking
    Missouri
    JB Weld, that's another good idea, I see it can withstand temps up to 500 degrees.
  10. Stihl Kicking
    Stihl Kicking
    Missouri
    Another good idea, I have the torch and solder.
  11. Ralphie Boy
    Ralphie Boy
    Problem solved! :salute:
  12. jo191145
    That’s what I was thinking. Sweat it just like copper.
  13. Horkn
    :thumbs::handshake:
  14. Theashhole
    Theashhole
    Osceola, In
    I'd say redloctite, might have to re-do in a year but you'd have to get that thing almost red hot.
    Stove gasket cement might work, it should handle the heat fine (that's it's main job)
    Sent from my SM-G950U using Tapatalk
  15. Backwoods Savage
    JB weld and duct tape will fix many things!
  16. buzz-saw
    buzz-saw
    Ct.
    I vote for red locktite.
    Easy and you have it on hand. If that doesn't work, then go to plan B
  17. TurboDiesel
    The plumber in me says solder it.:handshake:
    Locktite, superglue, CA glue for woodworking, nail polish,
    Cheese :whistle:
    :emb:
    :picard:
  18. Screwloose
    I think most all of these will work but personally red loctite is what I'd use first.
  19. Chud
    Chud
    I used the stove sealer so I’ll let you know how that turns out. There is a a 2nd poker with a screw on handle to keep me busy while the cement sets on the other one.
    Stihl Kicking likes this.
  20. Stihl Kicking
    Stihl Kicking
    Missouri
    I agree with Screwloose, I think most of these will work. I went for the red loctite, but it's evaporated, someone must not have tightened the cap properly. :whistle: So, I went for the JB Weld, due to convenience. I gave the rake a good brass cleaning before putting it back together, it shined up purty.
    Chud, definitely give us an update. I was a little concerned about the heating and cooling, expanding and contracting. I'll give an update also, although hopefully it won't be till the end of the season, for both of us.
    Before and after cleaning.
