Does anyone have a battery backup for power outages?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Cash Larue, Jan 24, 2022.
  1. Cash Larue
    Cash Larue
    Pine, CO
    Hi friends!
    It’s me again. I was just reading on Nextdoor, that someone up here by me lost power in the last snow storm while they were at work. When they came home, their house had filled with smoke, because their pellet stove hadn’t had a chance to cool down when the power shut off.
    Someone recommended getting an automatic battery backup to assist with cool down in the event of a power outage. Does anyone know anything about these? Anyone have one? How does it work?
  2. stuckinthemuck
    stuckinthemuck
  3. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    They are called a "UPS" UNINTERUPTIBLE POWER SUPPLY.
    They transfer to the backup battery within a nano second.....
    The UPS plugs into the wall and the stove plugs into the UPS.....
  4. badbob
    badbob
    If you have at least 3 foot of vertical flue, smoke in the house would be extremely rare.
  5. bogieb
    I have a UPS on each of my stoves. If a stove is running when the power goes out, it will gracefully shut down the stove by pulsing the exhaust fan (I guess that uses less power?). Harmans suggest specific UPS' that they have tested as working as described. Some people have actual battery backups on their stoves, hooked into a marine battery I think. But, I don't really know much about that.
  6. Rich250
    Rich250
    Berks County PA.
    I have a non sine wave, it's not one that harman has on their list but works as it should and shuts the stove down. A sine wave UPS will keep the stove running until the battery goes dead or power is restored or a generator is hooked up.
  7. corncob
    corncob
    Somewhere in Lower Michigan
    More popcorn content..
    No UPS here. None needed. We have a 30KW diesel fired backup genny plumbed into the tractor diesel (500 gallon) bulk tank that assumes the ENTIRE load from the farm in 45 seconds after the utility drops out (45 seconds allows the engine and generator to stabilize). Has a trickle charger on the starting battery and a vacuum transfer switch and provides seamless power. Ours is 3 phase and single phase 110-220. I've had it at least 10 years and other than routine care, it's flawless. When utility is restored, it transfers back in 15 seconds.
    I recommend a standby to everyone. Don't need one as large as we have but far as I'm concerned, it's the only way to go.
  8. Cash Larue
    Cash Larue
    Pine, CO
    Thanks for the helpful advice. :handshake: I just found Harman’s list of them and bought the Tripp Lite that they suggest.
  9. Cash Larue
    Cash Larue
    Pine, CO
    Good to know! Thanks:handshake:
  10. stuckinthemuck
    stuckinthemuck
    Do you have a link to the list and one to the item you selected? I may get one for my Harman XXV.
  11. Cash Larue
    Cash Larue
    Pine, CO
  12. stuckinthemuck
    stuckinthemuck
  13. Cash Larue
    Cash Larue
    Pine, CO
    I can try to track it down. I found it last night. Here is a screen shot from the owner’s manual online. Check out the first bullet point from the top. Sorry it’s a crappy pic.
  14. stuckinthemuck
    stuckinthemuck
  15. wildwest
    Wyoming high plains
    Yes, interesting, if power was out there wouldn't be any pellets feeding. Just what was already in the pot to burn out. Guess I'm comparing the house filled with smoke like WWW trying to start the woodstove in a strong inverted draft LOL.
  16. Cash Larue
    Cash Larue
    Pine, CO
    That’s a good point. I wouldn’t think the smoke damage would be too severe. But with small kids in my house, I’d rather not take any chances. Plus I wouldn’t want to open any windows to air the house out in the event of an outage, and lose the heat I do have. If your burn pot is full when the power goes out, it could potentially smolder for a long time. But you’re right - the smoke created would most likely be more of an annoyance than anything.
  17. wildwest
    Wyoming high plains
    Oh of course, I understand your concern. For sure I recommend a UPS too, I bought a brand popular on the pellethead thread, Cyberpower. Still curious about your friends though, there had to be something else going on for it to fill their house with smoke. Hope they got it checked out/cleaned/inspected to be safe.
  18. Cash Larue
    Cash Larue
    Pine, CO
    Yeah. I agree. Seems weird. It was just a random person complaining on the Nextdoor app. I don’t actually know them. I should be more specific when I say “Nextdoor.” There is some chance “house full of smoke” may have been a bit of an exaggeration on their part.
  19. bogieb
    Losing power is a great way to tell if your door gaskets are getting on the bad side. Smoke fills the chamber then goes out the method of least resistance. Sure, probably most of it will still go out the exhaust if you have a rise, but some will still go into the room. And it doesn't take much smoke to irritate, especially if you have family members with asthsma, CoPD or other issues.
    Plus, having a UPS will smooth out any spikes or lags in the current, which from what I have read on the Interwebz, is better for the control board.
    That is a pretty good price. I have the APS (which used to be recommended but they discontinued that model). Both are 6-7 years old and even back then they were around $80 on sale. Maybe I need to replace them - I know after a while the battery goes bad. Hmm, now you have me thinking, which isn't something I like to do at 3AM :D
  20. imacman
    imacman
    Denver, NC
    You can get replacement batteries on 'Zon or fleaBay. Much cheaper than a whole new unit. 6-7 years is probably about right for replacement. Make sure you pull the actual battery out of the unit to get the correct replacement model#.
