45-70 pro’s and con’s?
Discussion in 'The Game Room' started by J. Dirt, Jan 22, 2022.
  1. J. Dirt
    J. Dirt
    I’ve always wanted one and I’m partial to older cartridges so I’ve got one on order. What’s anyone’s thoughts? I’ve never fired one but it sounds like it’s going to be a good 100 yard brush gun. I’ve got a lot of thick hunting areas (mainly going to be for deer) and I’m not concerned about recoil. This rifle is a single shot with a muzzle break and from videos and reading it sounds pretty nice. Any preferences on ammo? Bullet weight style?
    FatBoy85 and metalcuttr like this.
  2. metalcuttr
    metalcuttr
    western WA
    I have a Handi Rifle with a 45-70, 30" Buffalo barrel (among others). It kicks like a mule with the Hornady Lever Revolution cartridges. I have also shot the Remington standard velocity cartridges with, I believe, a heavier bullet. Although I have not hunted with it, I think I would probably use the slower, heavier bullet for deer to lessen meat damage. Maybe save the Lever Revolutions for elk.
    FatBoy85 and J. Dirt like this.
  3. J. Dirt
    J. Dirt
    I’m kind of thinking the same with a heavier bullet. Hopes would be that bits of brush wouldn’t effect it as much. We have to slug hunt around here and the old 1 oz 12ga rifled slugs is what I’m guessing it will be similar to. A bit lighter and smaller diameter of course
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    DO NOT USE the 300 grain hollow points on moose. Other than that I got nuthin.
  5. J. Dirt
    J. Dirt
    Stick with the 500 grain solids? :faint:
  6. Sandhillbilly
    Sandhillbilly
    I would think the 300 gr hollow points would be fine on close range whitetails.
    I lost a nice bull moose in Alaska. There was 3 of us bow hunting basically, but had 1 rifle that the guy from Oklahoma brought along. A marlins guide gun 45/70, I was the only “gun guy” in the group. As soon as I seen the ammo I thought, “oh! Not what I would have brought, but I guess it’s what I got to work with”
    I hit a good bull 3 times, first shot almost knocked his front legs out from under him, so I know it was in the shoulder area. It just never got any penetration to the vitals.
    I don’t recall exactly but the bullets were around 300 gr and had a hollow cavity upfront. Might have been Remingtons. Turns out the rifle wasn’t even his, he barrowed it from a friend. He new nothing about guns…. Especially that one….
  7. metalcuttr
    metalcuttr
    western WA
    Very sad to lose an animal like that!
  8. Sandhillbilly
    Sandhillbilly
    Yep….. spent the entire next day looking
  9. metalcuttr
    metalcuttr
    western WA
    Correction as I read my notes: the two types of cartridges I have tried are the Winchester 300 gr hollow points at a listed 1880 fps and the Hornady Lever Revolution 325 gr pointed soft tips advertised at "250 fps faster than other brands" whatever that means. The LR bullets have a pointed soft tip that is safe in tubular mags. My experience as that the Winchesters were easier on the shoulder and grouped far better than the Hornadys at a higher velocity. I have heard from another source that he had a bad experience with the LR bullets on elk. I think the 300 gr Winchesters would be fine for deer but I would try a different brand than either of these with a heavier bullet for elk! This is assuming shorter ranges in brush or timber. reload.jpg
  10. J. Dirt
    J. Dirt
    Picking her up tomorrow!!
    Now if I can just find some ammo……
    FatBoy85, JackHammer, Horkn and 3 others like this.
  11. lukem
    .45-70 Ammo
    Looks like you are going to be in the $2.50 - $3.00 / round range.
  12. chris
    Nothing wrong with a 300gr or more hard cast, gas checked slug ( not hollow point). With the gas check should be able to hit the 1800 fps easily without leading. 300gr is what I use in my falling block. As I cast my own my cost is considerably less that $2.50/rnd.
  13. J. Dirt
    J. Dirt
    Well here she is! Along with a really expensive box of cartridges! 350gr flat solid nose bullets. Hopefully they shoot well since Id like to make them last! 10BEE9B2-4027-41E8-B3B6-EE1A7CCC73B3.jpeg
  14. Sandhillbilly
    Sandhillbilly
    I hope that recoil pad is effective. As light as that rifle looks that box of ammo will probably last a while.
    FatBoy85, Buzz Benton, Eckie and 3 others like this.
  15. Ejp1234
    Ejp1234
    MD
    it has less felt recoil than a 12g slug. 45-70 isnt that crazy of a kicker.
    metalcuttr, J. Dirt and Horkn like this.
  16. J. Dirt
    J. Dirt
    Honestly it’s heavier than it looks. I was surprised when I picked it up. Between the pad and the muzzle brake it is supposed to be pretty “friendly”
    Being a slug hunter, 30/06 fan and a 10ga Turkey gun guy I think it’ll be ok. :heidi:
    FatBoy85, Ronaldo, metalcuttr and 2 others like this.
  17. Sandhillbilly
    Sandhillbilly
    Don’t know if I’ve ever fired 12 ga slugs… but I have shot several different 45/70s, none of them are what I would call mild off the bench. But once sighted in and under field/hunting conditions they aren’t to obnoxious. Gun weight plays a pretty big role. A ruger #3 is a good example.
    Just my experience…
  18. Sandhillbilly
    Sandhillbilly
    I’m sure you’ll be fine, it’s not like you’re probably gonna take it out to shoot prairie dogs all day
    FatBoy85, Eckie, J. Dirt and 2 others like this.
  19. Horkn
    That looks just like my CVA optima V2 50 cal muzzleloader cva-optima-v2-50cal-muzzleloader-black-stainless-1369240-1.jpg
    XXL, FatBoy85, eatonpcat and 2 others like this.
  20. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Very nice! Guessing a CVA scout?
    I was looking at a CVA scout in .35 whelen
    FatBoy85, metalcuttr and J. Dirt like this.
