Help needed
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by jewilson, Jan 13, 2022.
  1. jewilson
    jewilson
    Fancy Gap Virginia
    Handshake to you all. I have spent the past couple of days trying to pass a 8” insulated stainless steel flue liner down my chimney. The darn thing went easily until the transition from Tera cotter to the top of the hearth. Worked all day getting nowhere trying to chip out bricks mostly by feel with a air chisel. Having a very hard time trying to enlarge the flue.
    Is there any tried and true methods I may have overlooked. Has anyone else had this problem before. Please help. [​IMG]
    wildwest, M2theB and Camber like this.
  2. Camber
    Camber
    Montana
    I welded up some lengths of rebar with a leaf spring steel sharpened to a 45 degree angle on the end. When I do remodels, I always seem to resort to using them. On occasion you can slip a 4.5 inch grinder in there with a mason wheel and score the brick every inch or so first. Then you can give them the ice chisel treatment. A roto hammer works better in my opinion to chip with compared to a air hammer.
    Rickyblazin, wildwest and jewilson like this.
  3. Camber
    Camber
    Montana
    Making score cuts with the grinder will help immensely with the air hammer if that is all you have. You can also buy 12 inch mason blades for a sawzall. If I'm understanding your picture correctly, it looks like you can access it just fine. Good luck to you. Just remember to study the project with structural integrity in mind.
    RGrant, wildwest and jewilson like this.
  4. jewilson
    jewilson
    Fancy Gap Virginia
    Yes it’s only got about 6’ or so to go. I have a hammer drill and a 41/2” angle grinder. Used them yesterday to remove the damper inside the fireplace and cut out the cast iron.
    Must have tunnel vision from working in a tunnel all day. Great ideas guys.
    Camber likes this.
  5. Camber
    Camber
    Montana
    You got this then.
    RGrant and jewilson like this.
  6. jewilson
    jewilson
    Fancy Gap Virginia
    You think I need a diamond tip blade or will the regular standard disk work.
    Camber likes this.
  7. Locust Post
    Just to score them a standard masonry blade should be fine. I had to do some of the same when I installed my 8" liner.
    Camber, wildwest and jewilson like this.
  8. jewilson
    jewilson
    Fancy Gap Virginia
    This material must be removed
    Been working on it three days making progress. Using a hammer drill and air chisels. Scraped up chest back and knuckles but I can’t quit now. This was before I started and after cutting out the damper. [​IMG]
    Camber and wildwest like this.
  9. wildwest
    We hired out a mobile welder for our damper, he had it cut out quickly.
    jewilson and Camber like this.
  10. Camber
    Camber
    Montana
    I don't know if this option is available for you, but since you live in a high population state; maybe you could call a day labor company and see if they have a midget available for a few hours? Less wear and tear on the body in tight spaces.
    Ron T and wildwest like this.
  11. jewilson
    jewilson
    Fancy Gap Virginia
    Success!!!!!!!!!!
    RGrant, Chvymn99, Locust Post and 3 others like this.
  12. jewilson
    jewilson
    Fancy Gap Virginia
    Stuck my 2 year old grandson up there. He fit good.
  13. wildwest
    :dex:
    Chvymn99 and Camber like this.
  14. Camber
    Camber
    Montana
    Good job! I think we are wearing the same sleepy pants and slippers. :rofl: :lol:
  15. jewilson
    jewilson
    Fancy Gap Virginia
    Yea. Wish I could got the insert installed before this snow storm. I’m too old for that type work now. After a good long shower I was ready to hibernate. Thanks for your assistance. Good to get help from someone who has been there and done that.
    Camber, Chvymn99 and wildwest like this.
  16. Ron T
    Ron T
    Northeast Ohio....Bowdil
    :cheers:
    Camber likes this.
