Muffler Mod Question
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Jan 12, 2022.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    So, I think I'd like to try a muffler mod for either, or both, my 362CM & 661. I see there are many places, including Ebay, to purchase a modded muffler. Prices range from about $20 to $100. Any recommendation as where to purchase a GOOD one?
    :salute:
  2. tamarack
    tamarack
    paulina oregon
    Egan performance chainsaw in Deary Idaho has aftermarket mufflers for the 362 and 661. A friend of mine has one on his 500i, very well made product.
  3. Screwloose
    On my 661 I just added one hole adjacent to the original one. I can take a picture later and give you the size. Seemed to help a bit. I don't think I would waste money on buying one mine was a empty can.
  4. Screwloose
    I should point out that on my 661 at least it is quite a bit louder. I've heard that the aftermarket ones are ridiculously loud.
    brenndatomu, JB Sawman, Ohio and 2 others like this.
  5. Yawner
    Yawner
    Louisiana
    I have an aftermarket one that is seriously loud on a Stihl 026. Appears to be not much more than a straight pipe! Well-made, though. Looks bada$$, sounds bada$$. Smokey the Bear doesn't like it, I am wary of starting fires!
  6. The Wood Wolverine
    M2theB, brenndatomu, tamarack and 5 others like this.
  7. Camber
    Camber
    Montana
    I believe I put a west coast bark box on my 500i that I sold. I believe it was around 50 to 70 bucks. Really helped that saw.
  8. huskihl
    huskihl
    I could do them but I’m swamped with port work right now. If 6 weeks works, let me know and I’ll have you send the mufflers/covers when we get there.
    362 would look something like this
    661 would look similar to this
  9. Ralphie Boy
    Ralphie Boy
    Time is no real issue. How much?
  10. huskihl
    huskihl
    $70-80 shipped for the pair
  11. Ralphie Boy
    Ralphie Boy
    I forgot the most important thing: Thanks!
  12. Screwloose
    That's a pretty good deal for sure.
  13. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Great thread Ralphie Boy , I’ve wondered if a custom fabricated muffler mod or an online purchased one are worth it many times.
    so does a muffler mod actually increase performance, or just let the saw run a littler cooler and much louder?
    M2theB, Screwloose, eatonpcat and 3 others like this.
  14. Ronaldo
    Ronaldo
    Mufflers are typically overly restrictive from the factory. So, opening up a muffler will increase performance by allowing the exhaust to escape easier and more rapidly. This will also allow the saw to run cooler and usually does increase the noise level to some degree. Catalytic mufflers are especially restrictive and hold heat. Most times after a muffler mod you will find it necessary to retune and give the saw a little more fuel.
  15. Ronaldo
    Ronaldo
    I like to put a pipe in and usually close up the factory opening. The pipes allow directing the exhaust where you want it and they give the saw a deeper, more throaty tone that doesn't increase the noise much.[​IMG][​IMG][​IMG]
  16. Eggshooterist
    Eggshooterist
    Erff
    In my experience, every one I've done has made a noticable difference once the carb is tuned correctly. Some saws are more choked off than others like the Echo saws I've owned / own. I muffler mod every 2 stroke piece of hand held equipment I have unless its an old vintage saw. They are usually open enough for what I do with them.
  17. Eggshooterist
    Eggshooterist
    Erff
    This is exactly what I started doing with 3/4" id tubing.
