Potato Peelings
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by JW IN VA, Jan 6, 2022.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    How many still use them to help keep creosote low?
    MikeInMa and M2theB like this.
  2. M2theB
    M2theB
    Central Massachusetts
    ill go first
    7?
    The Wood Wolverine and MikeInMa like this.
  3. MikeInMa
    Say what?
    M2theB likes this.
  4. The Wood Wolverine
    I'll go second.
    2?
  5. Chris F
    Chris F
    Micksburg, Ontario
    Never heard of that before. Sounds like it belongs in the "you can't burn pine safely" category.
  6. theburtman
    theburtman
    I had heard of it many years ago. My thought was why would you go to all that effort to have dry firewood only to throw wet garbage in the stove?
    MikeInMa and TurboDiesel like this.
  7. Eric VW
    Or throwing a tin can in the firebox… around here it’s tin, not aluminum. Like a Yoo-hoo can from back in the day.
    Apparently tin cans and potato skins contain creosote defeating chemicals… ya know, to scrub out what the chimney fire didn’t get after burning pine.
    :picard:
  8. JW IN VA
    JW IN VA
    Virginia mountains
    It seems most don't go along with what I've been told. I didn't mean to imply they would clean a chimney, just help prevent creosote.
    I don't know .
    TurboDiesel likes this.
  9. Hall84
    Hall84
    Hurt
    I’ve never tried it, but heard of the peeling and also rock salt. I was told you still need to sweep your chimney, but these would help with creosote build up.
    JW IN VA and The Wood Wolverine like this.
  10. The Wood Wolverine
    That makes 2. :D
    M2theB likes this.
  11. M2theB
    M2theB
    5 to go!
    MikeInMa and The Wood Wolverine like this.
  12. Monkeysocks
    Monkeysocks
    SE Minnesota
    Interestingly enough, this is technically true. The question is if the concentrations in potato peels and cans are high enough to have the same effect. Doing a spot check of the MSDS for three commercial Creosote remover products, the active/ingredient common to them is manganese acetate. (The actual percentage of manganese is withheld as a trade secret on the MSDS)
    Both steel and aluminum cans contain manganese as part of the alloy (~ 0.35 to 1% manganese) and the average potato contains 0.3 grams of manganese (most of which is concentrated in the skin).
    So potentially, they could work the same as the commercial products, converting the sticky tar-like creosote into the easier to remove flaky creosote.
    shack, Eric VW and Softwood like this.
  13. buzz-saw
    buzz-saw
    Ct.
    I cook baked potatoes in my stove , A little seasoning on them and wrap in foil then cook just inside the door on a few coals . They come out great and no clean-up.
    Does that count ??
    Warner, jewilson, JimBear and 3 others like this.
  14. Eric VW
    :handshake:
    I like the part about not removing creosote, but converting it into something easier to remove.
    :yes:
  15. Cheepbeer
    Cheepbeer
    NW Ohio
    I'd rather deep fry my potato peels.
    theburtman and MikeInMa like this.
  16. Softwood
    Softwood
    Central WI
    Hmmmm.
    JimBear likes this.
