What is this
Discussion in 'Chainsaws and Power Equipment' started by Eckie, Jan 10, 2022.
  1. Eckie
    Eckie
    Stumbled on this. Interesting, I guess...? I imagine it could take a bit of a learning curve. Probably safer than my come along and chains, depending on length, angle and availability of a helper....
  2. JimBear
    JimBear
    It’s a type of tree jack
  3. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    They are great when you have a smaller diameter tree and cant use wedges.
  4. TurboDiesel
    I wonder if theres a chain around the stump at ground level to keep the jack from kicking out
  5. Eric VW
    Our great friend and brother walt could wedge a popsicle stick over…
    :D
    :salute:
  6. walt
    walt
    north central ohio
    Thank you for the vote of confidence Eric. Tree felling is geometry , the most important tool you have is between your ears . I do like the looks of that tool , have never used one. I do have a stuby hydraulic jack with a plate for the top that I have used for a few stubborn trees .I always back it up with wedges .
  7. Backwoods Savage
    I am curious why the wedge cut out of the tree was not cut more square with the world? Looks like there was a possibility of some slippage there.
    MikeInMa, Hinerman and walt like this.
  8. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    :rofl: :lol::thumbs:
    Eric VW, walt and Screwloose like this.
  9. MikeInMa
    Maybe, uneven ground? Notch has to match the ground conditions.
