Splitter Modification: Asking the hive mind
Discussion in 'Chainsaws and Power Equipment' started by Eric Wanderweg, Dec 27, 2021.
  1. Eric Wanderweg
    I’m tossing around ideas in my head at the moment (I know, this usually doesn’t end well) ;) My County Line 25 ton has served me very well for the past year and a half or so. I’m wondering if I can make it better though by converting it to a push through design for when I’m dealing with elm or other hard to split pieces. Hypothetically I could cut the foot off the end of the I-beam, weld a wedge in its place and put a push plate in place of the splitting wedge on the ram. A little bit of work but nothing I can’t handle. BUT... once I do that, there’s no going back. So would it be that much of a hair brained idea to make a bolt on conversion kit that I can swap out if need be? Drill and tap some mounting holes in the splitter foot to bolt a wedge of sorts to, and make a pusher plate that’s a direct bolt on once I remove the factory splitting wedge from the ram? Does this sound reasonable/feasible or is it a lofty, impractical pipe dream that I should leave well enough alone?
  2. The Wood Wolverine
    I think an T.Jeff Veal mod would be better, allowing a bit of push through without cutting off the base.
  3. Eric Wanderweg
    Ahhh you’re right, I have vague memories of him fabricating up something for his splitter not too long ago. I figured someone would’ve thought of doing this at some point...
  4. Horkn
    Yep. T.Jeff Veal 's slip on adapter will help with elm and stringy stuff
  5. brenndatomu
    Agreed...once you cut that foot off it will never be as strong again...unless it is professionally welded and reinforced maybe...but as for bolt on, no, it won't hold...heck if you look around at well used 20 ton + splitters, its not that uncommon to see the foot a lil bent...bolts don't stand a chance IMO...
    Slocum, T.Jeff Veal, Horkn and 10 others like this.
  6. Ron T
    Ron T
    Northeast Ohio....Bowdil
  7. metalcuttr
    metalcuttr
    western WA
    What TWW said! Do a bolt or slip on mod like T.Jeff Veal did or buy a nice push through.
    Eric VW, T.Jeff Veal, Horkn and 7 others like this.
  8. amateur cutter
    FIFY Russ. :DC'mon Eric Schamell you know everybody needs at least two splitters right?
    I would do exactly what T.Jeff Veal & I think Erik B did & build the simple block for the wedge to push through. Way easier & cheaper, as well as very effective.
    Slocum, Eric VW, T.Jeff Veal and 8 others like this.
  9. metalcuttr
    metalcuttr
    western WA
    Sorry....I don't know What I was thinking!:loco: :crazy:
    Eric VW, T.Jeff Veal, Horkn and 3 others like this.
  10. Chris G
    Chris G
    SE Tennessee
    Can anyone link this thread about the mod? I'm intrigued!
  11. Erik B
    Erik B
    Western Wisconsin
    Chris G Which mod are you looking for?
    Eric VW, T.Jeff Veal and Horkn like this.
  12. Chris G
    Chris G
    SE Tennessee
    The splitter mod they are talking about in the posts 2,4,7 and 8.
  13. Horkn
    Who likes elm
    This one which is similar to t.jeff veal's, it's actually Erik B's Screenshot_20211228-215646(1).png
    I like this because it's a slip on. Put it on when needed, pull it off when not.
  14. T.Jeff Veal
    I tried tubing at first, but it bent. It was bolted on, since I don't have a welder. Erik B's is nice, though, easy on/off.
    I have only had to take ours off once or twice, for a customer that wants 24-25" long splits.
    Either design works great. We have had some hickory that came from the same place, some stringy, some straight grained. 0825202118.jpg 0825202119.jpg
    jk14, Eric Wanderweg, Slocum and 10 others like this.
  15. Erik B
    Erik B
    Western Wisconsin
    The 'tube' pieces on the one that I made came from upright stakes on a logging truck. Something had happened to them as they were bent but I got a couple small straight pieces from it for my build.
    Slocum, Chvymn99, T.Jeff Veal and 6 others like this.
  16. Casper
    Casper
    I spent a ton of time on "free" steel making a second beam to swap out with the factory beam. I machined it, welded and assembled a cutting edge with a slip over 4 way. It worked great, right to to the point a kotty piece twisted it. I started a new wedge and different beam design. The I-beam I used worked, but it flexed a little. New design is boxed tubing with an internal spine welded in. Will Posted pics when I get around to finishing. I will be able to reuse the pusher and that had the most time involved, especially after dropping the cylinder attach points. It was too high.
    Here's a few pics and a video pre-fail.
    20201003_193002.jpg 20201003_191848.jpg 20201003_191854.jpg 20201002_184410.jpg 20201002_184355.jpg 20201005_181407.jpg
    Post fail...
    New wedge made from A36 plate:
  17. Softwood
    Softwood
    Central WI
    Why not AR500?:D
