best method to spread guide bar channel
Discussion in 'Chainsaws and Power Equipment' started by Sourwood, Dec 23, 2021.
  1. Sourwood
    Sourwood
    Popcorn, IN
    My Husqv 24 inch is pinching the chain on both sides of the bar, one the "engine" end of the bar. Been tinkering with a screwdriver and a hammer. Just wondering what you all may use when maintaining your bar.
    Dang things are running 90 bucks to replace.
    brenndatomu likes this.
  2. Chris G
    Chris G
    SE Tennessee
    A lot of times with heavy use the channel of the bars will mushroom out. You can take a file and remove the metal that has squeezed into the channel and that should some that issue. As far as spreading the channel I have nothing useful to contribute.
  3. Lehman
    Lehman
    Minnesota
    Did you recently replace the chain ? Maybe got a wrong gauge chain in the box or if it’s an older chain and it got thrown it could have some bent or mushroomed drivers on it. Can’t see the grove closing unless it got pinched bad or bent a little in one spot.
    brenndatomu and JimBear like this.
  4. JimBear
    JimBear
    Just use a large flat screwdriver to open it up, if it’s too wide when your done, close it back up with a 2x4 & hammer. I found just using a hammer will pinch it back if not careful.
    brenndatomu and Mag Craft like this.
  5. Lehman
    Lehman
    Minnesota
    90$ for a 24” bar? Is it a light bar or just the standard Oregon built husky bar? I can get a replaceable nose Stihl 25” for about 70$. I thought an Oregon was about 50-60$
    brenndatomu, Mrxlh and JimBear like this.
  6. Lehman
    Lehman
    Minnesota
    The bar tools work pretty well too, has two bearings with one adjustable just put pressure on the tool and run it up and down the bar.
  7. JimBear
    JimBear
    I saw one of those somewhere & then couldn’t find the link again. Do you have a link ?
  8. Lehman
    Lehman
    Minnesota
    I saw them on eBay years ago but I’m betting a person could make one real easy with a couple cheap bearings and a few bolts and nuts
  9. Lehman
    Lehman
    Minnesota
    On eBay, looks fairly simple to make
  10. JimBear
    JimBear
  11. Fifelaker
    Fifelaker
    Fife Lake Mi.
  12. JimBear
    JimBear
    :headbang::doh:
    Brain cells are a terrible thing to waste…
    Fifelaker, MikeInMa and brenndatomu like this.
  13. Lehman
    Lehman
    Minnesota
    I know just got derailed into the bar closer which is a far more common problem. I did ask him if chain was a new one or the old chain got thrown, maybe not a bar issue at all.
  14. Mag Craft
    Yep I always use a screw driver when opening and one of the tools with two bearings on the side when closing.
  15. Mag Craft
    Good point. It could be that the chain drivers have mushroomed a little and are now binding in the bar groove.
  16. Sourwood
    Sourwood
    Popcorn, IN
    Nah the chain isn't new. Been sharpened a few times by now. The shop said they would just use a screwdriver but I thought someone here may have learned a better way.
    Lehman likes this.
