Anyone try this trick to heat your house with your clothes dryer?
Discussion in 'The DIY Room' started by don2222, Dec 10, 2021.
  1. B.Brown
    B.Brown
    USA
    What about the moisture that the dryer takes out of the clothes as they are drying? Does this go into the house as well, since you are using the vent to help heat the inside of the house?
    JackHammer, TurboDiesel and billb3 like this.
  2. corncob
    corncob
    Somewhere in Lower Michigan
    Not true in our case. Choice is propane or electric and we get a reduced rate on the dryer and HWH. I vent ours into the house in the winter to provide moisture and heat. Been doing that for years now, 'cause I'm cheap.
    mat60 and Sandhillbilly like this.
  3. don2222
    don2222
    Salem NH
    Do u have a lint trap when you vent into the house?
    mat60 and eatonpcat like this.
  4. eatonpcat
    You guys are nuts! IMO if you are trying to heat any portion of your house with your dryer :picard:
    How often are you running this dryer. Definitely not smart enough to argue, but CMon man!
    Eckie, Ron T, mat60 and 1 other person like this.
  5. corncob
    corncob
    Yes Don and I'm not really interested in the heat factor but more the humidity from the drying clothes and how it impacts the RH in the house. I like to keep my RH around 50% if possible. Easier on my nose and the furry creatures too.
    I use one of those bypass boxes you can get at ACE with a mesh bag attached to it to catch the lint.. Turn it inside out and the lint falls off. Been doing that for years now. Flip the flapper one way for summer, the other way for winter. Easy peasy.
  6. don2222
    don2222
    Salem NH
    The ACE units seem very helpful.
    Ace Heat Diverter
    Ace 4 in. L X 4 in. D White Plastic Heat Diverter - Ace Hardware
    Ace Lint trap
    Ace 4 in. W X 4 in. L White Plastic Lint Trap - Ace Hardware
    Erik B, mat60 and corncob like this.
  7. corncob
    corncob
    Not overly expensive either. Comment above about heatin the house with a dryer I find humorous. I just want the humid air that is going outside. Nothing more and it saves my buying bottled water for the humidifier as out well water is loaded with calcium and kiss a humidifier wick in less than a day.
    Jack Straw and Erik B like this.
  8. Ohio dave
    Ohio dave
    Akron, OH
    I tried
    That 1st unit pictured worked ok. And there's a damper on it to let it all go outside for warmer days. Never used to actually replace the furnace just when there was laundry to dry.. With 3 kids in sports at the time that was multiple times a day. Wife didn't like it, but she only goes in the basement for laundry. I have a work bench and a bunch of aquariums down there so I liked it...
    But happy wife happy life so its gone
    mat60 likes this.
  9. DaveGunter
    DaveGunter
    Heat pump dryers are awholenuther level of efficient, and they are ventless. They are pricey however and take twice as long to dry the clothes.
    Hang the clothes outside in the summer...that's free.
    Jack Straw and mat60 like this.
  10. billb3
    Believe it or not, Summer can be the worst time to dry clothes outside if it is hot and stupid humid with no wind. They just get hot in the sun if there is no wind.
    I haven't used my dryer for 15 years. I have a clothes line outside and a small one inside.
    A windy day in Spring, Fall or Winter and they can be dry in half an hour if it is also relatively dry.
    Electric here is 29¢/kwh so three loads a week saves me somewhere between $1.25 and $4.00 a week. Plus my clothes last longer.
    Not a big chunk of change, but it would be for a family of four or more.
    I don't live without a dryer to save money per se, but because one thing I began noticing in world travels is that the rest of the world pretty much uses clothes lines to dry clothes. I figure so can I.
    mat60 likes this.
  11. TurboDiesel
    Electric heat is 100% efficient. :p
    Jack Straw, brenndatomu and mat60 like this.
  12. Cheepbeer
    Cheepbeer
    NW Ohio
    There is exactly zero chance mine would collapse.
    TurboDiesel and Jack Straw like this.
  13. TurboDiesel
    Mine might collapse, with or without pulling a vacuum on it... lol
    Eckie, Ron T, Jack Straw and 2 others like this.
  14. JackHammer
    JackHammer
    Yeah. Long term this could cause mold.
    Jack Straw likes this.
  15. don2222
    don2222
    Salem NH
    That is why I did not buy a house with a damp basement. :)
  16. corncob
    corncob
    ...and the most expensive per realized BTU.
  17. JackHammer
    JackHammer
    The book " a river runs through it" was written about my basement.
    Eckie and Ron T like this.
  18. LinkedXJ
    LinkedXJ
    I cant imagine the comments from my wife if i had some duct work like that from the ceiling to our dryer.
    Eckie likes this.
