372 and 088 videos
Discussion in 'Chainsaws and Power Equipment' started by mdavlee, Aug 12, 2014.
  1. mdavlee
    mdavlee
    I got a couple videos from today of the 372 and 088. The 046 isn't cooperating and may have slipped timing. I'll have to pull the recoil and check. It wouldn't turn over 11k no matter what the tune was.
  2. cory@owen
    cory@owen
    Nice!
    mdavlee likes this.
  3. Birddogtg
    Birddogtg
    Central ohio
    088 looks real fast
    mdavlee and SquareFile like this.
  4. SquareFile
    SquareFile
    somewhere
    Square file on the 088?
    Heck of a rooster tail coming out!
    concretegrazer likes this.
  5. HDRock
    Man that 088 is trying to pull you right in there
    HoneyFuzz and Chvymn99 like this.
  6. Chvymn99
    Wow....Both them looked good:thumbs: But I think the 088 stole the show...
  7. mdavlee
    mdavlee
    I don't remember actually. That chain was filed about 3 months ago. I'll look tomorrow and see. It was 404 with an 8 pin. I don't have any full comp .063" chain right now to make a loop up to switch it to 3/8" and a 9 pin.
    The 372 is stock. It's the one I bought on here back the first of June or so.
  8. bryanr2
    bryanr2
    that 088 is immmmmmmmmppppprrrrressive.
  9. cory@owen
    cory@owen
    Is this port work only? Did you cut the base or squish band?
  10. Well Seasoned
    That 88 ripped!
    mdavlee likes this.
  11. DexterDay
    The 372 was nice, but Dayuum that 088 was a mean machine! ! :dex:
    Chvymn99, mdavlee and MasterMech like this.
  12. mdavlee
    mdavlee
    It came this way to me from out west. Squish is set on it but no machine work done to it. The 372 will be getting some machine work here soon.
    Cut4fun and Chvymn99 like this.
  13. mdavlee
    mdavlee
    The chain on the 088 was round filed. :popcorn:
    Cut4fun, Hedgerow and SquareFile like this.
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Flat out impressive :)
    Chvymn99 and mdavlee like this.
  15. cnice_37
    cnice_37
    Oh man.... the 088 fever is about to go rampant. Nice saws Mike.
    I have been staring down the cylinder of my 038 wondering how to make a Dremel an acceptable porting tool. My sloppy hand and tight wallet are telling me to just put it back together stock. Please share some pics of your setup when you attack the next saw.
    clemsonfor, HoneyFuzz and SquareFile like this.
  16. mdavlee
    mdavlee
    I've got a dremel flex shaft that I used before I got the cc specialty right able and stuff to go along with itm if I had room for a lathe I'd be all set. I'm going to tig a muffler mod on the 550 here shortly.
  17. Hedgerow
    Hedgerow
    SW Missouri
    The right angle tools are the shizz...
    mdavlee likes this.
  18. mdavlee
    mdavlee
    Yes they are. I can' believe I got along as long as I did without them.
    The 046 had slipped timing when I tightened it probably challenged about 15°:headbang:
    Cut4fun likes this.
  19. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mike, great stuff! I'm wondering how the member designed saw will come out after you port it. Perhaps a before/after porting set of videos.
    I'm not a big Stihl fan but the 088 just smoked the 372!
    Great Job!
    Tim
  20. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    As I said about the bidding on the member designed saw, if the bidding goes over some number (I forgot the number) I am going to throw in a bar and chain which will probably be .058 and Stihl square cut chain, just for laughs!
    Chvymn99, Hedgerow and mdavlee like this.
