Good firewood trailer for ATV or UTV
Discussion in 'The Wood Pile' started by Yawner, Dec 5, 2021.
  1. Yawner
    Yawner
    Louisiana
    I have a Honda Foreman 500 ATV and also a John Deere Gator UTV, side by side, whatever you call them. I would like to be able to haul more rounds out of the woods than the Gator bed (and the Honda has no bed!). Anything new out there in 2021, has anyone found a trailer that works well? My trails have humps and bumps, they're just leaf-covered dirt. I will need to widen them by harvesting more trees to accommodate a trailer. I have two small trailers, one 4x8 and one 5x8 but I consider both of those too large unless I *really* widen the trails. I just pull those behind the truck, they are street trailers. The 4x8 might possibly work but still, it's larger than what I figure is practical. I also like to go off-trail some to get close to a tree I am harvesting. I wish I would have looked into this prior to Black Friday! My luck somebody held a big sale!
    Cash Larue, Loon, WinonaRail and 6 others like this.
  2. PatrickNY
    PatrickNY
    Putnam County, NY
    I got this lil bugger at HarborFreight. It's only 40"x48". Not sure if that's too small for what you need...? CCCD7015-EC14-4155-A2D1-43B7F5DFCE38.jpeg A3E19B3A-AFF6-4E69-930D-36D8C3214E23.jpeg EAD7DF86-31D9-4630-A31F-7D7B71ACE20D.jpeg
    Cash Larue, Farmchuck, Loon and 13 others like this.
  3. Chazsbetterhalf
    Chazsbetterhalf
  4. Yawner
    Yawner
    Louisiana
    That's cool, Patrick, I didn't realize they have a trailer that size. I assume it is a kit. My brother got the bigger cousin from HF and it has held up just fine for several years. But he doesn't haul anything heavy. And I would! Your trailer could certainly work. Wider wheels would be better, though. Might could buy some. The good news about my trailer size needs are is that I don't need big, small is fine, because I poop out after I cut, load, unload and stack one about the size of yours!
  5. PatrickNY
    PatrickNY
    Putnam County, NY
    Yes, Yawner, it's a kit. I added the plywood and the sides. I just looked at the HF website and didn't see this one there. I bought it about a year and a half ago. Good luck.
  6. PatrickNY
    PatrickNY
    Putnam County, NY
    Thanks, Chazs. The pics are from the Spring. Woodshed is all full now, plus approx 2 more cords next to it.
  7. Horkn
    I use the 4x8 trailer when I can behind the ATV. If that's too wide for the trails, I use a 10 cubic foot agrifab dump trailer. If there's a good amount of snow, I'll use the jet sled behind the ATV.
    Here's the sled.
    I'll say this though, get as wide of tires as you can on any trailer for hauling wood. Many of the yard carts have narrow tires, and those sink in and cause ruts. Same applies to the 4x8 trailer. The trailer I used to use had skinny tires that would rut up yards badly. The older 4x8 I have now had much bigger and wider tires. It's a lot better for not rutting up the yard.
    Cash Larue, Loon, eatonpcat and 7 others like this.
  8. Horkn
  9. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I have an ohio tool. Added sides. Back doesn't have place to put pickets. I didnt realize I would miss not having them. 20211125_083434.jpg
    Was pretty solid until this happened. :headbang: 20211125_104638.jpg
    I like it, but don't know if I would buy it again or recommend it, with other options
    Cash Larue, Loon, eatonpcat and 6 others like this.
  10. Slocum
    Slocum
    North Central Indiana
    What’s the size of your bed on your gator?
  11. Reloader
    Reloader
    NW Oregon
    I’ve hauled many loads with this little trailer. [​IMG]
    Sent from my iPad using Tapatalk
    Cash Larue, Farmchuck, Loon and 17 others like this.
  12. clemsonfor
    Yea it's a kit. They have 2 sizes and one folds. It has like 975 pieces or something too!! Haha
    They have those tandem axle ATV type tire off road trailers that can hold a good bit.
    Those 4x8 tires will cut down pretty good in soft dirt. I wonder if those pontoon trailer type tires 8x20x10 or whatever they are would fit in the fenders there like 3x as wide.
  13. sirbuildalot
    sirbuildalot
    Mass
    I was gonna say the Yutrax trail trailer seems pretty popular, but Reloader beat me to it.
  14. clemsonfor
    Those are the type I was thinking of.
  15. clemsonfor
    Can you get enough tongue weight on that to keep from spinning tires? It's tandem but due to the short length it's almost looks more like a wagon.
  16. Horkn
    It's a single walking axle, so tongue weight shouldn't be an issue
  17. SloMoJoe
    SloMoJoe
    SW Michigan
    +1 on the Polar HD 1500. I’ve been beating on mine for 10 years now, hauled somewhere around 90 cords with it, and it’s still as good as new.
    The side rail kit lets me hold 150 splits. I put a wheeled jack stand on it, and it became a movable firewood pile in my garage. That saves restacking the wood, and the tub contains all the mess,and keeps my garage cleaner.
    I got the 4 wheel kit, and the rocking axle makes it ride a lot smoother. The extra tires make it about the same width as a UTV.
    If I wreck it, I’d be lining up to buy the exact same thing again.
  18. M2theB
    M2theB
    Central Massachusetts
    100%
    I was telling the war department earlier this evening what a good purchase that was
    Duelies eliminate any yard sales that single axle brings and tongue is long enough to eliminate short radius jack knives while backing up.
    Lay a piece of plywood over the bottom and you’ll be happy with the Yutrax
  19. Yawner
    Yawner
    Louisiana
    I don't know, can't measure, is at my woodlot. Why?
    I have two...
    2009 Gator 850D XUV 4wd, diesel
    2008 Gator TX 2wd, gasoline
    As for the diesel 4wd, I see these specs...
    Bed Length (in/mm) 43.9 / 1116
    Bed Height (in/mm) 9 / 229
    Bed Width (in/mm) 49 / 1244
    Bed Capacity (lbs./kgs.) 1000 / 454
    Cargo Bed Material Steel
    Bed Volume (ft3/m3) 11.2 / 0.32
    Even if I didn't put any wood in the Gator bed and only used a trailer for that, I still have to carry quite a bit of stuff in the Gator bed. The way I am doing it now, I only have room for wood in about 2/3 of the bed. (Chainsaws, fuel, oil, gear, mauls, etc.)
  20. brenndatomu
    I think that JRHAWK9 has the 4 wheel version of that one too...
