Freezer and electrical question
Discussion in 'The DIY Room' started by Sirchopsalot, Nov 26, 2021.
  1. eatonpcat
    Nerd!! :p
  2. Sirchopsalot
    Sirchopsalot
    medium city in CT
    We had an energy audit, there was a minor refund if we upgraded. But the fed refunds were enticing....$800 a year or two back. It would be a matter of shelling out a grand or so. I'll install myself or with someone that wants coffee/beer/a meal.
    Sca
    T.Jeff Veal and brenndatomu like this.
  3. billb3
    Heat rises when it uses air as a lift mechanism.
    People rise when they use an elevator or escalator. Sometimes even their own legs on stairs.
    T.Jeff Veal and Sirchopsalot like this.
  4. Eric VW
    I disagree, in a friendly way, rest assured.
    To “Rise” denotes upward, vertical motion. Ascension, in a sense.
    Heat radiates omnidirectionally. There is no rise to it.
    Our sun is radiating-central in our little solar system. If one could look in from afar at our outer galactic little neighborhood and ask, “”where is the “up” or “rising”, as in “above?””
    There isn’t. We are warmed by the sun throughout the path of our orbit. No more or less if our orbit were somehow rotated 90°.
    A bonfire burning on bare ground heats everything above the tops of the feet.
    A charcoal or gas grill (an elevated fire, so to speak) is felt from the height at which its radiated heat has an initial straight line path to a body, but even later it will radiate in all directions from the skin of its fire holding vessel.
    So if heat truly rises, and not merely heated air- then how do we accept that we get warm standing at a bonfire without standing above the bonfire?
    Some will say semantics… potato potahto… but we’re often reminded of other word/thought salad topics regarding firewood, so I thought I would give my 2¢ on putting this old wives tail in its place.
    Change my mind.
    T.Jeff Veal, brenndatomu and Aje1967 like this.
  5. Creekin
    Creekin
    Manitoba
    What I've noticed is in my shop with radiant floor the temp is virtually the same at floor level as 18' up
    Very tight built construction/air sealing
    Friends shop, same square footage, radiant floor, poorly air sealed, temperature at floor level is noticeably cooler than 18' up
    My thinking is that the drafts pull warmth from the concrete which decreases its density by heating up and therefore rises forcing cooler air downwards in a convective cycle
    Not exactly were I'm going with this but helps me to visualize what heat does
    T.Jeff Veal, brenndatomu and Eric VW like this.
  6. Creekin
    Creekin
    Manitoba
    Heat doesn't rise, but heats 360°, heated air will rise (convection)
    Want to put down more smart words/terms but not sure if i can spell them
  7. Canadian border VT
    Leaving the solar system out of it.. for I am just an uneducated redneck; light a candle hold your hands 1 foot apart, flame between them, move around candle heat is same.. hold hand 6” below candle; not same as sides; hold hand 6” above candle now go get ice for burnt hand:cool::smoke:
    ask and ye shall receive
    I agree that heat likes to migrate too cold because opposites attract
  8. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Didnt get the timer for the freezer....makes sense to leave it on and consistently cold.
    Its 52 in the pantry...fridge only keeping food 10° colder than room temperature. kitchen temp 70 with wood stove going.
    Sca
  9. T.Jeff Veal
    For you hot water, have you thought about the Point of use units? Instant hot water. Install under the sink or the bigger units can install on the side of the house. Available in gas or electric.
  10. eatonpcat
    If heat rises, why is my beer always warmer when I get to the bottom?? :coldone:
    TurboDiesel and brenndatomu like this.
  11. Eric VW
    :picard:
    brenndatomu and T.Jeff Veal like this.
  12. billb3
    It rises to the occasion ?
    T.Jeff Veal likes this.
  13. chris
    Point of use units are a pain if you have a lot of desolved items in your water like calcium, lime and iron to name the 3 most notorious for plugging up the works. With the way appliances are made now days getting 8 years out anything new is a gamble. Not that they can't be repaired, if you don't mind sticker shock for parts, if still available.
  14. TurboDiesel
    Because, when you get to the bottom, the can is upside down.:handshake:
  15. brenndatomu
    Good point, the can is full of hot beer breath by that point! :rofl: :lol:
  16. Eric VW
    Good points, men.
    It also occurred to me upon welcoming eatonpcat at walt ’s this past October and :handshake: with him…
    Very warm and sweaty right hand Richard choker.
    :eek:
    EW GOSS!!!!
  17. brenndatomu
    T.Jeff Veal, eatonpcat and Eric VW like this.
  18. Eric VW
    Probably the cleanest part of that whole set……….
    :salute:
  19. brenndatomu
    Yes!
  20. brenndatomu
    Remember "mama had eyes in the back of 'er head....and she could getcha with her boomerang shoe from around the corner!"?
    Hilarious!
