This is your warning
Discussion in 'Everything Else (off topic)' started by TurboDiesel, Nov 24, 2021.
  1. TurboDiesel
    Wish i knew how to do that...
    All the youtoob videos work but the youtoob "shorts" dont...
  2. The Wood Wolverine
    Shorts seem to be when using your phone. When I use my laptop and embed the vid, it works fine.
    Is Chickanic a tictok alternative?
  3. Eric VW
    This was your link… I circled the YouTube address for you to see how to fix this…
    The pertinent info in this fix is the “o_bQgINOx” and if you (in a forum post “Edit”) highlight that and copy it- you can add the following text to your in-edit post and paste the copied code into the embed code…
    Here’s what it looks like when you type it out, which I can’t do or the site software will actively try to embed something.
    Just be sure to “preview” after your edit to make sure everything is correct, and then be sure to delete the YouTube “…feature=share” link.
    Have fun!
  4. wildwest
    That vid is the same one I saw, but it started with 2 cycle shortage. Which would explain why I've not been able to order it for 6 weeks via walmart. WWW mentioned aluminum cans require magnesium, so watch out beer and soda lovers. Wouldn't be bad to go back to all glass bottles, mfg in USA and return/recycle.
  5. Backwoods Savage
    Thanks Eric.
  6. Eric VW
    :handshake:
    :yes:
  7. Backwoods Savage
    Why are you up so early? (Or is it late?) Go to bed man!
  8. TurboDiesel
    Dude! You know I'm a pipe fitter, right?
    That's only about one notch above caveman/sasquatch...:emb:
    :salute:
  9. brenndatomu
    FIFY :whistle: :D
  10. TurboDiesel
    Dude!!:eek:
    I got feelings!!:hair:
    :startled:
  11. Eric VW
    I guess the only one you had just got stepped on…
  12. TurboDiesel
    Luckily i left them in the cloak room when i signed in...
  13. brenndatomu
    "cloak room"...they still have those?! :jaw: :p
  14. Eric VW
    That gives Tim’s age away… just a little bit…
    :wacky:
    :D
  15. brenndatomu
    Eh? :BrianK:
  16. eatonpcat
    The cloak room is in front of Tim's parlor where he sits on his Davenport! :BrianK:
  17. tree killer
    tree killer
    Central me
  18. TurboDiesel
  19. TurboDiesel
    You should see my cardigan sweater.:rofl: :lol:
    Chazsbetterhalf, walt, Chaz and 3 others like this.
  20. TurboDiesel
    Omg
    I think thats what i just put in the stove room. :jaw:
    Seriously!
