Splitter problem
Discussion in 'Chainsaws and Power Equipment' started by chainsawsoldier, Nov 16, 2021.
  1. chainsawsoldier
    chainsawsoldier
    NE Kansas
    So after splitting a bunch of crotch pieces today, I was cleaning up the beam and noticed this… 003EFDDE-890B-4309-98A6-D3257518E90B.jpeg A14816BA-12BA-48BE-972F-43EE561650E9.jpeg so I guess my next job is to heat this up and weld it back down.
  2. mat60
    mat60
    ME
    I guess not a good weld job from from factory. Good that you have what you need to fix it.
  3. Chris F
    Chris F
    Micksburg, Ontario
    That's another reason why I like to split vertically. You can keep the wood out of the groove so it can't distort the wedge plates like that. Crap doesn't build up there in the first place because it's vertical.
    I split two log truck loads with my first splitter without that problem then I sold it to my brother. Within a month he had one of the plates bent up like that and he splits horizontally.
    That should be an easy fix though.
  4. Horkn
    I think that's more of a design flaw with some splitters, rather than splitting horizontal vs vertical.
    This type and others that ride right on the beam don't have that problem. When the groove is a welded on piece, it won't be as strong.
  5. Fifelaker
    Fifelaker
    Fife Lake Mi.
    After 7-8 years and around 100-120 cords through it mostly horizontal mine has never given me a problem. It is a little different than this one it's a Husky 22 ton, the beam grove is rolled not welded.
  6. Chris F
    Chris F
    Micksburg, Ontario
    Yeah, that's a far superior design. My 3ph splitter I sold this summer was built like that.
    Horkn and amateur cutter like this.
  7. Horkn
    That's how my mtd is, also the troy bolt is an exact clone. This pretty much mirrors the commercial splitters too.
    amateur cutter, Chris F and mat60 like this.
