I think its dry
Discussion in 'The Wood Pile' started by bobdog2o02, Nov 14, 2021.
  1. TurboDiesel
    I think you've reached the age where your wood will start to degrade.
    Eckie, metalcuttr, JimBear and 9 others like this.
  2. brenndatomu
    Come on now, you gonna set Dennis off! :rofl: :lol:
  3. Eric VW
    If it’s under great, solid, splash back-free cover, I’d say it would suffer minimal degradation.
    Husky Man, metalcuttr, Horkn and 7 others like this.
  4. JRHAWK9
    JRHAWK9
    Wisconsin
    I've seen zero signs of it on the wood which has been kept dry. I had a row or two tip into the adjacent ones within a year of being stacked. This exposed the bottom of these rows to the elements for a good 5-5.5 years. Some of those splits where degraded, dry and very light, but still burned fine. I am past those now and everything looks great.
    Just tested a red oak re-split now before loading and it was a dripping wet 17.5%. :D
    Here are two larger splits that are 6.5 years old. Just took this today. Over 30 lbs for two splits of oak.
    Nice thing about older stuff is a lot of splits shed their bark just from being handled now.
  5. Farmchuck
    Farmchuck
    Nepa
    How long ago was it cut and split?
    metalcuttr, savemoney, Horkn and 5 others like this.
  6. amateur cutter
    Mid way thru the Great Depression.:rofl: :lol:
    Eckie, metalcuttr, savemoney and 8 others like this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    3 years, 1 year in single row in the yard with no cover, then 2 years in the wood shed.
  8. TurboDiesel
    Sounds like a perfect system, Aardog.
    :salute:
    :handshake:
  9. yooperdave
    Doesn't he have a "coyote" to help him out now???
  10. Horkn
    Ruffage!!!
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I dont get it?
  12. Sirchopsalot
    Sirchopsalot
    medium city in CT
    My favorite question when wearing a kilt "is anything worn under a kilt?"
    Nope, everything is in perfect working order.....
    Sir McFarlane Chopsalot.
  13. iowahiker
    iowahiker
    NE Iowa
    My guess is Lamppa Kuuma furnaces operate better on 18% moisture firewood because they are totally electronically controlled. The moisture would slow the temperature swings so the control system can keep the burn clean and in the control zone. Control systems have "lag" times which very dry firewood could "our race". One more point of interest: EPA moisture specs are on a wet basis while moisture meters read on a dry basis. If Lamppa Kuuma uses wet basis then the moisture meter equivalent would be 20%+ moisture firewood.
    metalcuttr and savemoney like this.
  14. TurboDiesel
  15. TurboDiesel
    Drunk posting?
  16. bert the turtle
    bert the turtle
    If I load my warm pizza oven the night before and let it bake bone dry it absolutely for sure no question burns better in every way.
    I’d like to talk to the actual engineers, of that stove (not the sales guy or front office guy) and see how they manage to keep their allegedly optimal 20% wood at 20% after it’s been in the firebox an hour.
    Husky Man, metalcuttr and savemoney like this.
  17. The Wood Wolverine
    Multiple reference to that in other posts so I'm not convinced, yet. :rofl: :lol:
    metalcuttr, TurboDiesel and savemoney like this.
  18. lukem
    You can have too much too dry wood in my boiler, especially if they are smaller pieces. The wood will gas off faster than the secondary burn can handle and it will run dirty. I don't know what the moisture content numbers are but I can for sure burn wet-ish wood cleaner than I can burn ultra dry wood.
  19. Canadian border VT
    lukem I’m wondering if manufacturers are designing them the way the general population uses them. Meaning if the average person burns xx moisture wood then only design the secondaries to burn so much per hour. I’m not an engineer but it makes sense that it’s cheaper to build and design something with a smaller range of operations than a larger one
  20. lukem
    With anything you engineer to a specification...and their specification for moisture content and the resulting gasification rate was probably based on what they considered, on average, to be dry cordwood that most people would actually get. But when I burn scraps from the shop or framing lumber cut-offs, that's more than it can handle, and understandably so.
