Husqvarna 372xp Leaking Oil + Stihl BG55 Blower
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Oct 22, 2021.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Tree guy brought over a Husky 372xp that is puking bar oil all over the place. He also brought with him a Stihl BG55 blower whose choke switch keeps flapping around and 2 seconds after you hit the gas it slips into choke and kills the engine.
    Started with the blower and when I took it apart I could see why this was happening. What an absolute garbage cheap design they have for the choke. It's two pieces of plastic linked together by a square hole and matching peg, but held tight only by one of those absolute cheap azz metal washers with teeth in it.
    I figured if I replaced the lever mechanism and the washer, it would eventually just happen again so I decided to drill it out. Went with a 1/8" bit and that left plenty of meat on the square peg. Home Depot near me did not have #5 (1/8") screws so I went with 3mm, 2 washers, and a nut.
    Worked awesome. The switch is nice and stiff now with a drop of loctite blue and it ain't going anywhere as long as nobody slams it. He's going to use this at his house and I told him as much. There was some wear on the exposed part of the lever and I just can't get over how bad this design is.
    I'll probably order a spark plug for this unit although it didn't look that bad.
    CRAP DESIGN!
    That black tab that is supposed to hold the lever in the RUN position is not big enough and actually wore a groove into the orange lever.
    You can see the groove here.
    Ended up just slicing the peg off flush with the square peg part of the lever.
    All fixed
    Part 2 coming up for the Husky.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    Stihl BG55 videos.
    Part 1.
    Part 2
    Part 3
    B.Brown and amateur cutter like this.
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    Husky 372xp
    So this thing had oil leaking out the flywheel side, all over the clutch area, all over my garage. It's probably a ripped hose but I can't do anything until I order the clutch removal tool.
    Here are some pics.
    Needs a new 3/8" 7T rim sprocket. Old one is shot. Slight damage to the case protector shield at the bar mounting studs but I can just trim it clean and leave it. Haven't pulled the spark plug yet but could probably use one.
    2021-10-22 11.46.06.jpg 2021-10-22 11.46.11.jpg 2021-10-22 12.02.12.jpg 2021-10-22 12.03.01.jpg 2021-10-22 12.03.08.jpg 2021-10-22 12.03.15.jpg 2021-10-22 12.04.22.jpg 2021-10-22 12.04.25.jpg 2021-10-22 12.06.09.jpg 2021-10-22 12.06.16.jpg 2021-10-22 12.09.10.jpg 2021-10-22 12.09.13.jpg 2021-10-22 12.09.26.jpg 2021-10-22 12.10.10.jpg 2021-10-22 12.12.17.jpg 2021-10-22 12.14.44.jpg 2021-10-22 12.15.26.jpg 2021-10-22 12.15.29.jpg 2021-10-22 12.32.18.jpg 2021-10-22 12.32.21.jpg
  4. LordOfTheFlies
    LordOfTheFlies
    NY
    amateur cutter and M2theB like this.
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    Hyway aftermarket spur sprocket. $18.38.
    Sprocket rim, drum & bearing 3/8 7 tooth fits Husqvarna 362, 365, 371, 372, 570, 575
    amateur cutter likes this.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    The drum should be replaced no? The rim sprocket looked like it was sitting in there fine but the teeth of the drum are rounded off a little.
    Hm.
    Rim sprocket $9.32 on Amazon.
  7. huskihl
    huskihl
    The drum is fine as long as it doesn’t wobble back-and-forth on the bearing when it’s in place. Don’t replace it with that type spur sprocket you have shown, as that’s more for a homeowner set up. I wouldn’t use an aftermarket replacement drum anyway, unless it was an Oregon
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    Got it. I looked up the Oregon one and it has been discontinued. I ordered the just the rim sprocket and the tool from HLsproparts. I forgot to check the crankshaft wobble. Will do so now. I saw some people post that they had to use some kind of sealant to plug up leaks on the oiling system of this saw. Is that normal???
  9. huskihl
    huskihl
    The number is probably superseded to a new one. I am 100% certain it’s still available. But there’s no need to replace it if it’s relatively snug once it’s in place. The rim sprocket itself is the same as any 70cc and up Stihl as well. So you can get them at the dealer if you want
    The oil leak just depends on what’s wrong with it. There’s a brass tube that comes out of the top and that could be cracked or worn through. The only other connection is where the hose meets the tank. If I have one apart, I degrease everything and put sealer on the hose and the pump when I put them back together
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    Drum fits snug and it looks like it relatively new metal needle bearing in there so yeah I'll just replace the rim sprocket then. Thanks.
    What kind of sealer do you use? I have a tube of automotive RTV gasket sealer. Will that work? Or do you suggest something else? Looks like I might be busy fixing this guy's stuff going forward heh heh.
  11. huskihl
    huskihl
    Yeah that’ll work. Just use it sparingly. And make sure there’s absolutely no oil on the case, pump, or hose
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    Got it. Thank you for your help as usual.
    amateur cutter, M2theB and huskihl like this.
  13. LordOfTheFlies
    LordOfTheFlies
    NY
    Took that case protector shield off and the brass part looks good. Saw is not leaking and I've had it flipped on both sides for a while now. Makes me think it's near the oil pump - worm gear, pickup line, or output line.
    This is what it looked like before cleaning up.
    SimonHS, amateur cutter and M2theB like this.
  14. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    How’s the case gasket look?
    Wiggle that crank… these saws are worse than 1125s for bearing problems. Normally there are idle issues, though.
    +1 on everything Huskihl said.
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Clutch tool from ebay is what I use. It’s the socket style that works in an impact or conventional socket with breaker bar.
  16. LordOfTheFlies
    LordOfTheFlies
    NY
    I did wiggle it and it is sturdy. No movement at all. Case gasket looks ok so far. As I said no leaks after it was pouring all over the place when he first brought the saw over. Not sure if he had tried to run it right before he brought it over.
    I haven't tried to start it yet. I just wanted to take a look first and see if there was anything obvious that could be fixed. What surprised me was that there were several spots on the flywheel side where there were pockets of bar oil.
    Yeah the one I ordered was $16 so it's probably pretty similar. Looks exactly as you describe. Do you really need a breaker bar to break it loose? I haven't needed one yet but maybe those big boy saws (i.e. this one) require more force?
  17. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Some saws (see: junk cases that have been run hard and long), yes. 99% of the time I use an impact against compression to remove clutches.
  18. LordOfTheFlies
    LordOfTheFlies
    NY
    As oppposed to using a piston stop you mean? Do you fill the jug with fuel or oil from the spark plug hole?
  19. M2theB
    M2theB
    Central Massachusetts
    I do have a couple clutch removal tools but oddly not for a Husky
    for that c spring clutch I block the piston and use a screw dribbler
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I’m against hard piston stops, yes. I use rope but typically only when torquing things down (fw nut and clutch). For removals, I use an impact against compression (no added oil) most of the time. I converted to this method after using rope and sockets/extension for a few years.
