Missing part..
Discussion in 'Chainsaws and Power Equipment' started by Chaz, Oct 10, 2021.
  1. huskihl
    huskihl
    Seems only fair. I figure they had our help in releasing it.
    Oh wait, did I just say that? :zip:
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Lol
    The aftermarket muffler mentioned above-
    They are “ok” for this series but may require a spacer for 034 cylinders. Some have a baffle but a large exit. The bolt holes are quite often “off.” OEM, as always, is your best option.
  3. The Wood Wolverine
    huskihl did this loose screws or did the spot welds fail? Just cure-E-azz. :rofl: :lol:
  4. Chaz
    Chaz
    Southwestern NY
    Well, he doesn't have physical access to it at the moment.
    I can't honestly say one way or the other.
    Although, I would think there would be cracks and/or tears if it was broken spot welds. I'm not seeing that at this point.
    $.02
  5. Horkn
    It looks just as someone thought earlier. Self tapping screws let loose.
    Chazsbetterhalf, M2theB, Chaz and 3 others like this.
  6. amateur cutter
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    Make fun of hello kitty saw all you want Kevin, you saw it run.
  7. Chaz
    Chaz
    Southwestern NY
    I thought "Hello kitty" was Korean or Japanese.
    Not up on these new trendy things.
    :p
  8. Chaz
    Chaz
    Southwestern NY
    Big thanks to huskihl for fixing up the muffler for me.
    :handshake:
    Looks great and I'm sure it'll last a long time.
    UPS took up pretty much all of the downtime, but that's all in the rearview mirror now.
    Still way faster than USPS these days.
    :picard:
    Had to modify the top cover a bit, but since it had a hole through it.. not so much of a problem by me.
    I will likely replace the chain brake, but for now will have to be content to check it to see if it's getting too much heat.
    Thanks again Kev.
    :handshake:
  9. huskihl
    huskihl
    Without having an 034/6 here to mock it up on, I was mostly concerned with it not interfering with the case. Got her a touch high I guess.
    Oh well. You needed a reason to cut that burned spot out of the cover anyway:yes:
  10. brenndatomu
    Good on ya huskihl ...extra snausages for you tonight! ;) :thumbs:
    eatonpcat, Fifelaker, M2theB and 7 others like this.
  11. Chaz
    Chaz
    Southwestern NY
    Yep, it's not the prettiest mod job, but better than a melted hole.
    :emb:
    The work you did is top notch. No complaints here.
    :cheers:
  12. Scotty Overkill
    Just another fine example of why huskihl is a top-notch guy! I was gonna offer to fix the muffler for Chaz but as I was perusing down through the thread, low and behold, I saw Kevin already did it.....
    Made me smile today when everything around me is a mess.....
    Top notch stuff right there!
    Chaz, make sure the tune on your saw is still good (if Kevin opened that hole up any more). Might need richened up a tad.
    Stephiedoll, eatonpcat, Chaz and 6 others like this.
  13. buzz-saw
    buzz-saw
    Ct.
    You noticed that too.
    I didn't want to say anything ; you know in today's world people are so sensitive and I didn't want to upset anyone.:rofl: :lol:
    eatonpcat, Chaz, Softwood and 4 others like this.
  14. Chaz
    Chaz
    Southwestern NY
    Thx Scotty
    :yes:
    Seems to be running just as well as it was.
    :saw:
    eatonpcat, Nixon and Scotty Overkill like this.
