Missing part..
Discussion in 'Chainsaws and Power Equipment' started by Chaz, Oct 10, 2021.
  1. Chaz
    Chaz
    Southwestern NY
    Hey guys, started cutting on the Edit.. darn "autocorrect".. logpile today, when the saw started to get very hot on the left hand. Called it quits to investigate, as the Poulan trigger is sticking.
    :picard:
    So this is what I'm looking at on the left side of the muffler. Not sure what happened to the piece that is meant to cover that hole, or redirect the exhaust. But it's not there, and I can't find it.
    I assume it's easier to replace the muffler itself. Anyone know what part number I might need?
    Stihl 034AV.
    The damage..
  2. Chaz
    Chaz
    Southwestern NY
    These part numbers look correct?
  3. M2theB
    M2theB
    Central Massachusetts
    Red97 used to stamp exhaust hoods out in different sizes. Very reasonable.
    Just need to do some final minor form fitting, clipping and couple holes for some screws.
    Good opportunity to open up the exhaust port some while it’s like that.
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    There’s a few options for 1125 mufflers. I’d replace the deflector as mentioned above. Check that the stamped steel options will cover the existing holes.
    Some 034-036 muffler conversions require a spacer and an extra 1125 gasket.
  5. Chaz
    Chaz
    Southwestern NY
    That's a bit above my pay grade at the moment.. perhaps once I have another quality runner then I can tinker.
    Still have a blank check for a MS261, but I kinda blew the budget this year with the building.
    :makeitrain"
    Slocum, Chud, Chazsbetterhalf and 8 others like this.
  6. brenndatomu
    If a guy wanted to take advantage of the day, I'd bet you could cobble a deflector out of a beer can for donor material...or a soup can if you wanted a little longer lasting model :dex: :thumbs:
  7. Chaz
    Chaz
    Southwestern NY
    It's spitting rain off and on now.
    :confused:
    But that's a gooder idea
    :yes:
    Got the Poulan running as well. Some corrosion on the throttle pin was hanging things up. Tore it apart and cleaned things up with the dremel.
    Needs a new plug and air filter as well.
  8. Chaz
    Chaz
    Southwestern NY
    Hmmm.. wonder where I'd find a donor beer can.
    :sherlock:
    :rofl: :lol::rofl: :lol:
  9. LordOfTheFlies
    LordOfTheFlies
    NY
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
  11. huskihl
    huskihl
    I’d keep your original muffler. Shoot me a PM if you want and I will braze a deflector on yours for you and send it back
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    The ones I have here (034/036/360) do not have that deflector.
  13. huskihl
    huskihl
    Feel free to peel off and send me the Chinese kitty sticker. I’ll affix it properly on amateur cutter ’s 036
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the starter handle second from left is crooked
  15. Chaz
    Chaz
    Southwestern NY
    Thanks huskihl much appreciated.
    I tried to fab up something from some leftover siding/roof steel.. couldn't make anything that would fit.
    :picard:
    Unsure, I'm not the original owner.
    This may be a muff mod from the previous owner.
  16. Chaz
    Chaz
    Southwestern NY
    Looks like it was attached with self tappers, the top hole is opened up compared to the other hole.
    Bottom one probably came out, and vibration worked the other one loose as well.
  17. Chaz
    Chaz
    Southwestern NY
    Nice lineup
    :binoculars:
    :cool:
  18. huskihl
    huskihl
    It is
  19. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Lol. I loved getting those stickers in orders. During the height of the pandemic, they were sending multiple stickers and business cards for PPE… “together we can stop COVID-19,” they read. Maybe a sort of “my bad” from across the Pacific?
    Those ones are the easy to access part of the obsession. Others are out on loan or buried behind 1122s.
    I keep thinking I’m done with 1125s but get the itch to build ‘em every year.
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Darn it! I’ll go fix it for ya. Mennonite kids just don’t know how to put things back haha.
