I can't get the 55 to run right
Discussion in 'Chainsaws and Power Equipment' started by HDRock, Aug 7, 2014.
  1. HDRock
    First off it has set for a while and I couldn't get it started, pull the plug there was no gas in there, dribbled a little bit into the cylinder and got its started, yes I had it choked and pulled it about 20 times
    It's inconsistent RPM's are up and down whether it is in wood or out of wood.
    It will run right for a bit and then start dogin out.
    I am pretty green when it comes to working on chainsaws, but I managed to get my other saws tuned good
    Can't get it tuned, it still has the little wings on the screws, the screws only turn like a half of a turn
    any guesses?
  2. clemsonfor
    Sounds like carb rebuild time. Maybe trash in the strainer in carb..maybe bad diaphrams??
    HDRock likes this.
  3. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    You might want to have a look at the impluse grommet, if dried out or cracked replace it! HVA part # 505 31 07-51. New carb HVA # 503 28 15-04 $72.
  4. HDRock
    I could do that if I knew where the impulse gasket was to look at it :)
    so what does a new carb cost?
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Look at the IPL!
  6. HDRock
    yeah I figured I would have to do that I did download one when I got the saw.
    Not sure if Jon replace that or not I will have to look in my files
    I guess it's time to start learning some more here do some studying
    papadave likes this.
  7. clemsonfor
    Also the fuel line if split or deteroriated can cause erratic running conditions.
    But its a line not really a gasket. But dont know every thing about your saw either.
  8. HDRock
    fuel line was replaced before I got the saw, a few months ago
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    I didn't do a whole lot to that saw, it was mostly a janitorial project. I did replace the fuel line, but that and the .325 rim sprocket were the only new parts I added.
    Carb rebuilds, if that's what it needs, aren't hard, and the kit is probably $10 or so.
    clemsonfor likes this.
  10. HDRock
    There he is :)
    OK, so the fuel line is the only new line then?
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    Yep. My memory's a little fuzzy, but I don't think the 55 even has an impulse line.
  12. DexterDay
    No it doesn't. .
    But it does have what KilliansRedLeo said above. That little rubber grommet will crack and cause an air leak (which is what your problem sounds like).
    It is inserted into the cylinder and the plastic intake partition has a small little tube that goes into the grommet.
    HDRock and clemsonfor like this.
  13. clemsonfor
    Yea check and replace what the experts said. And hes carb rebuilds on these are simple. Its usually harder to get the carb off than the rebuild.
  14. clemsonfor
    How long ago was the line put on and do you use ethanol fuel? (I'm sure its an ethanol rated line though and even if you do its probably good for years.)
  15. HDRock
    Found it, 07-51
    Do I need numbers off the carb to get a kit It's a Zama
  16. HDRock
    The fuel does have ethanol in it 'I always put sta bil in
  17. clemsonfor
    Stabil does not eliminate the effects of the ethanol, it just keeps it from going bad as fast. Ethanol still eats some types of rubber with stabil as well as ethonol is a moisture sponge....maybe the stability helps this a bit but I am not sure I'm not ip on all that stabil does.
    If there were more than one part based on carb brand I think it would specify this part w/zama carb this past w/walbro etc. I did not open the attachment to check myself sorry. It may of only come with that carb....but I'm no rancher expert​
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    As long as you are going to replace the impulse grommit you might as well replace the part right next to it 503 16 16-02.
  19. DexterDay
    I agree, both of those rubber pparts should be replaced.
    When I changed mine, they were both brittle and on their way out.
  20. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    And be careful when putting the carb back on IT IS VERY EASY TO STRIP OUT THE PLASTIC!!!! Given that you should also check out the plastic partition to make sure it is not already stripped out causing the carb not to seal and causing you problems!
