Gravity sux....
Discussion in 'The Wood Pile' started by MikeInMa, Oct 8, 2021.
  1. MikeInMa
    ....things down.
    Same rack from other side
    I was away for a few days and came back to that. I usually am able to correct any leanings, but need to catch them before gravity wins out.
    All fixed
  2. Stinny
  3. rainking63
    rainking63
    Old Lyme, CT
    Ooooof! Feel your pain brother. Had to restack an entire holz hausen last year.
  4. The Wood Wolverine
    That sucks. Happened once to me before I put snow retention things on my garage roof. A large snow slide pushed it right over.
  5. 288lite
    288lite
    Minnesota
    That is the reason I don’t stack much these days but I feel bad for you I know how much work goes into that
  6. In the Pines
    In the Pines
    Been there done that, more than I like. When I start seeing a lean I push it back the best I can, usually that works.
    Sometimes it just shrinks so much it needs restacked. Plus the dang moles making the ground unstable. Pallets compensate for that usually.
  7. ReelFaster
    ReelFaster
    S.Jersey
    Same here, had a rack go down earlier this year! Glad all is back in order :yes:
  8. buZZsaw BRAD
    If a log rack falls in Mike's yard and nobody is there to hear it does it make a noise?
    Ive had it happen before. If you have racks the same size parallel attach a strip of wood 1x3, 2x4 etc. on the end to them all. Locks them together. Lessens leaning and toppling.
    My half cord stack of mulberry has a good lean and i pushed it back. Checked it today and still up.
  9. MikeInMa
    I've had several fall, over many years. Haven't heard one yet.
  10. Well Seasoned
    Had that happen to me this summer! Irritating!
  11. MikeInMa
    Yeah. That sounds about right. No blood, no foul.
    The way it tipped over, left most of the splits on end. 16in of not bending over!
    Took about 30 mins to restack.
  12. Scotty Overkill
    I hate it when that happens!
  13. Eric Wanderweg
    Whenever you fall, I’ll be there for you ~ The Ground :cool: Sorry Mike, I know your pain all too well myself.
  14. MikeInMa
    A couple of Aleve took care of any pain. :thumbs:
  15. Husky Man
    Husky Man
    Mt Hood Oregon
    I have had to restack some because of settling during seasoning, fortunately it hadn’t “Unstacked itself “ yet, wait that migh have been less work.
    I have found gravity to be “Inconvenient “ in many ways
    I doubt that anyone ever called a 3120XP a Light Saw, but it balances very nicely with the 36” B&C, the 44” B&C is a tad nose heavy, but I sure didn’t expect as much difference between the 44” and 60” B&C’s as there is, that dayum gravity really Sux then, fortunately the 60” and 72”(I haven’t even had that mounted yet) are just for milling, and once the CSM is on the rails, I’m not supporting the weight.
    Doug :cheers:
  16. MikeInMa
    I believe there was a similar pic at the Ohio gtg. Impressive looking saw. :dex:
  17. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I feel your pain. Had a black bear topple one of my stacks a couple weeks ago. Heard a noise around 0300 and when I shined a light out back, there was a good-sized bear rummaging around in the overturned stack. Not sure what he was looking for, but he didn't even offer to help restack the wood.
  18. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Welcome to 'Club Tip Over' you are in good company here! Most of us have had it happen one time or another. It's all part of the game of wood hoarding.:salute:
  19. MikeInMa
    Bears get used to ripping apart rotting logs, looking for grubs and such. Figured your stack to be an easy bust-apart. Then went away shaking its head, realizing he had wandered into the FHC realm.
  20. Gavorosalini
    Gavorosalini
    Hutchinson KS
    Saw a few pieces on the ground today turning into the drive. Went out after supper, said a few choice words and started restacking. As if stacking isn't a chore already. Thought about this post too. Bout 30 minutes of banging and stacking to be done. Guess it has shrunk enough to settle. Also wondering if the grade down to the river was just enough to do the deed or my lack of stacking skill.
