Using a digital tape measure - anyone else try it?
Discussion in 'The DIY Room' started by don2222, Aug 28, 2021.
  1. don2222
    don2222
    Salem NH
    Hello
    Not a big deal but I thought I would try one just to see how it works.
    It has two memory banks for storing the last two measurements. Also can show metric or US units of inches & feet.
    You can also set it to stop measuring on the left side or the right side.
    In the example below, I measured the width of my roll around cart’s table top which is 18-3/16 inches or 1’ 6-3/16 inches.
    Any comments?
    Pic 1 - table top width measurement
    Pic 2 - close up of results
    mat60 and Camber like this.
  2. Camber
    Camber
    Montana
    I had a kid that bought one for siding. It worked ok, but not on rough surfaces. I taught him how to read a tape and it is probably in one of my tool trailers. As a builder, I can't think of a use for one that a good ol' fashioned tape won't handle. Only gadgets I really keep are the lazers for work.
    JackHammer, mat60, Screwloose and 3 others like this.
  3. brenndatomu
    We have a non contact "measuring tape" at work (laser I think?) I find the main place that it's handy is for long runs where the tape is too short to do it all in one shot, or you would need help to hold the tape in place. We honestly don't use it much...one of those things that sounds great, but then turns out meh...
    mat60, Screwloose, metalcuttr and 2 others like this.
  4. don2222
    don2222
    Salem NH
    Yes, I have one of those also and it does not seem to read correctly on close distances. Does yours?
    mat60, Screwloose and brenndatomu like this.
  5. brenndatomu
    Been a while since I tried it...don't recall honestly.
    mat60 and Screwloose like this.
  6. lukem
    I have a laser one I use for measuring warehouses at work. I've never measured how accurate it is, but I mostly just need it for column lines and ceiling heights (30'-60' range). Being off a couple inches is no big deal.
  7. eatonpcat
    Same here, it is close enough for column to column, floor to ceiling and even measuring joint or truss sizes.
  8. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I have a Bosch laser one and was using it as much as possible during my wraparound front porch build from the ground up. Just to see how it worked in real life.
    Working alone without someone to hold the other end or trying to stiff leg a tape across a span was the best advantages.
    Surprisingly, it’s more accurate at 1/16” +- than I am with my tape measure!
    It took me a while to trust it and I still would verify occasionally.
    It also measures area in square feet, cubic feet, and the height of a wall using two measurements for the triangle math.
  9. mat60
    mat60
    ME
    I had a helper back in the day that could have used one. Had to tell him 16 and three little marks.
  10. Screwloose
    I could see it being handy for measuring in places that you couldn't actually see the tape. Underneath, inside ect. Stretch it out, store the dimension and pull it out and read it.
    Otherwise I think it would sit until the batteries leaked.
    JackHammer, eatonpcat and mat60 like this.
  11. Screwloose
    My wife worked for you ????
  12. mat60
    mat60
    ME
    :rofl: :lol::rofl: :lol:
    eatonpcat and Screwloose like this.
  13. JackHammer
    JackHammer
    I also have a Bosch laser. I don't need it that much but I am impressed when I use it.
  14. Qerz
    Qerz
    I'm using a DEWALT laser and its meseasure's accurate. Even I have another bunch of DeWalt and Bosch tools, Both are reliable to use.
    mat60, don2222 and eatonpcat like this.
  15. Eric VW
    Just how big you roll yours???
    :eek:
    :whistle:
    :wacky:
  16. mat60
    mat60
    ME
    :rofl: :lol::rofl: :lol::salute:
    eatonpcat and Eric VW like this.
  17. eatonpcat
    Long, strong Fatties Brother!:whistle:
    mat60, Warner and Eric VW like this.
