026 Oil Cap
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Sep 5, 2021.
  1. buZZsaw BRAD
    My circa 1992 026 is leaking oil from the cap. Any recommendations for a replacement. Old screw in type. Dont want flippy caps either.
  2. stuckinthemuck
    stuckinthemuck
  3. huskihl
    huskihl
    Dealer usually has them in stock for $6-7
  4. farmer steve
    farmer steve
    top of the hill york co. PA.
    OEM Brad. Like Kevin said, reasonable at the Stihl shop. Not a fan of aftermarket caps.
  5. buzz-saw
    buzz-saw
    Ct.
    Is there an " O " ring on it?
    Maybe you can just change it if so?
  6. farmer steve
    farmer steve
    part#0000-359-1210 is the O-ring #
  7. buzz-saw
    buzz-saw
    Ct.
    BINGO " ,
    I would be willing to bet that this might be the fix.
    As long as the cap screws on.
  8. buZZsaw BRAD
    I didnt check, just noticed oil leak. Tightened but i think i may have stripped it as it tightens then "pops"and gets loose again.
  9. buzz-saw
    buzz-saw
    Ct.
    Sounds like a new cap might be in order.
  10. amateur cutter
    Yep, cheap enough. I bought 6 each oil & fuel caps as they fit multiple saws.
  11. metalcuttr
    metalcuttr
    western WA
    This is interesting. If they make replacement old style caps that fit my flippy cap 260 pro than I may ditch the flippies and go old school. Hate those flippies!
    buZZsaw BRAD and farmer steve like this.
  12. huskihl
    huskihl
    You can’t swap from flippy caps to screw caps, or vice versa. But there are replacement flippy caps on eBay that don’t have all the fancy crap inside of them and actually work really well
  13. metalcuttr
    metalcuttr
    western WA
    Thanks huskihl , for clarifying that. The oil cap on my saw requires a lot of fiddling around to get it to seal properly. Even a flippy that works ok would be an improvement.
    buZZsaw BRAD likes this.
  14. huskihl
    huskihl
  15. metalcuttr
    metalcuttr
    western WA
    huskihl and farmer steve like this.
