Thinking about a small saw
Discussion in 'Chainsaws and Power Equipment' started by blacktail, Sep 7, 2021.
  1. blacktail
    blacktail
    PNW
    With a big mess of limbs to tackle, it might be my time to jump on the 2 saw plan. Lugging my 290 around this mess is a chore.
    I have stihl pro shops nearby, and Lowe's & HD for husqvarna and echo. What's a good light weight saw for occasional firewooding? I cut 4+ cords a year and it's always been with my 290.
  2. Eric VW
    I’ve had great experiences with my MS170, some here could take it or leave it… The MS180 (maybe not anymore, IDK) had an adjustable carb, the 170 does not.
  3. Chud
    Chud
    A friend picked up a 150 for $120 last week and he said it will melt through small wood. If you’re looking to spend big on a pro Stihl the 201tc’s are little rippers. The 194t is a little cheaper. The Echo 2511t’s are toy saw light and cut nicely. Stihl also has the 150tc which is there smallest pro top handle.
  4. MikeInMa
    I've cut lots of wood with my non-pro Husky 435 and 445. Both 16in. I still use them both, 3-4cord a yr.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Horkn, JimBear, Eric VW and 4 others like this.
  6. The Wood Wolverine
    Thanks for the shout. 346 is a ripper and punches way above its weight class. It would be his new favorite saw. :)
    If you’re looking for super light weight, the 136 is that. @ only 36cc it isn’t a light saber.
  7. amateur cutter
    If you're going new I would take hard look at the Echo saws for sure. Less $$ than Stihl or Husky & good saws. For what you're doing & I assume not climbing I'd stay away form a top handle, they're easy to sling around, but also tend to kick back more easily. All that being said, I'd buy Jason's ported saw & put the 290 on a shelf till you need it. A well ported 346 is a light & wicked fast saw. In a 16 to 20" log I'd bet on the 346 over the 290 every time in the softer woods you have out there.
  8. Locust Post
    I'll Echo that, my little CS 400 is a breeze to use for limbing.
    MikeInMa, Horkn, Eric VW and 3 others like this.
  9. Backwoods Savage
    It seems many have already forgotten you are asking about a small saw. But as I read your post it brings back memories. I cut with a 290 for many years with that being my only saw. (That saw is now owned by ReelFaster.) My wife kept after me that I should a smaller and lighter saw that I could use at least for limbing. I held off but because of my terrible back I finally gave in.
    I talked to many folks and even borrowed a 250 once. Talked to the guy at the saw shop. Then talked to a man who had the task of fixing saws and had done so for many, many years. Without batting an eye he guided me to the 180. I asked him if that wasn't just a toy saw as it just seemed too small to me. He then told me that is the saw he had been using for years cutting his own firewood and said I would be happily surprised.
    Well, I bought one. Super light but more power than I expected. I probably use that saw the most! The only thing I noticed right away is that the chain does seem to need sharpening much sooner. Probably because of the narrow kerf, but its small size does not take long at all to sharpen. All in all, I like that little saw and would recommend it.
    tamarack, MikeInMa, huskihl and 8 others like this.
  10. BCC_Burner
    BCC_Burner
    Marble, CO
    Depending on budget, don't overlook the Husqvarna 540i XP. I bought one earlier this year, and haven't fired up either of my gas saw since I got it.
    bert the turtle and Horkn like this.
  11. moresnow
    moresnow
    "Lightweight/occasional firewooding". Stihl 170,180. Husky 136. Something along these lines would fit nicely in softwood country for sure. For heavens sake you could wipe out the pictured limb wood with a battery powered saw! Take all advice with a grain of salt. Mine included naturally.
    My go to small work saw is a little old Stihl 009. Rips nicely. Gets used far more than originally anticipated. Unfortunately it has a few components NLA if needed. Enjoy shopping.
  12. Horkn
    I used to use an 029 super as my only saw. Cut a ton of wood with it. Great saw, but not light. That 029super and the 290 are pretty comparable. You'd really appreciate a lighter saw for limbing and smaller stuff.
    I moved up to a dolkita6421 for the bigger stuff, as it's not much difference in weight from the 029s, but a lot more power.
    Then I won a ms170 at Dennis's GTG this past May. I really like the light weight and it rips pretty good too.
    My dad purchased an ms211cbe and that is a great light weight saw as well, with a little more power than the ms170. Both have the 16" pico chain and bar.
    I think you'll find that if you were to get one of the smaller Stihl saws, that you'd use that a lot more than the 290. Then you'll find that since the 290 sits, and you'll occasionally want a bigger saw that actually performs like one and you'll either sell that 290 or just add a bigger pro style saw for the bigger stuff.
  13. blacktail
    blacktail
    PNW
    That's a pretty good testimonial.
    I got the last one they had in stock and ran almost 2 tanks through it today cutting up branches.
    Stephiedoll, Ohio, Eric VW and 8 others like this.
  14. Backwoods Savage
    Congratulations. May that saw serve you well for many, many moons.
  15. amateur cutter
    :thumbs: good choice I'd say! Your dealer's inventory looks about as sad as mine. The dog really dresses up the pic though.
  16. The Wood Wolverine
    I bet you’ll appreciate that saws light weight. Two thumbs up for a new saw score!! :thumbs:
  17. Horkn
    You'll really like it! While I've never used a 180, it appears to be almost the same as a 170 except 2cc's more.
    I heard there's ways to mod these things to get even more performance from them, but so far I'm pretty happy with my ms170. Maybe when the warranty is over I'll mod it.
  18. blacktail
    blacktail
    PNW
    Plenty of work for the 290 after this morning.
    20210910_093441_011_saved.jpg 20210910_093638_010_saved.jpg 20210910_095715_009_saved.jpg 20210910_103851.jpg
  19. dennish
    dennish
    Nor Cal
    I'm thinking about getting the ebay refurbished (by Husqvarna) Husqvarna 120 ll for $135. What yall think?
    MikeInMa likes this.
  20. tamarack
    tamarack
    paulina oregon
    Looks like Cedar! Is that you that did the climbing?
