Work Done in 2021
Discussion in 'The Wood Pile' started by thewoodlands, Dec 31, 2020.
  1. T.Jeff Veal
    Nice stacks, beautiful woods and deer
    Chazsbetterhalf likes this.
  2. T.Jeff Veal
    Getting it done. Good job
  3. T.Jeff Veal
    That's a good one, right there...;):thumbs::rofl: :lol:...
    Y'all can pick on me this winter...:shiver:...
  4. T.Jeff Veal
    I cleaned up a bunch of culls and shorties this morning... 0812211206_HDR.jpg
    Over the past couple weeks, working a day off, here and there, we cleaned up a big hickory, twin willow oaks and a big pecan limb.
    We hauled 8 loads between the 2 places...
  5. thewoodlands
    thewoodlands
    I grabbed another two loads of Birch rounds out of the gully this morning and finished off the front and the back, the back stack needs some smaller rounds that will finish it off, we have some Ash, Maple and Birch rounds that will finish off the back rack.
    After the above is done, I'll move the chit wood near the blue tarp over to the outside fireplace and get our stacking areas ready for the fall felling.
    I stopped to take a picture of the first load after it was split and the fawn came running by and then stopped to eat at the base of a small Ash I felled last fall.
    JimBear, T.Jeff Veal, EODMSgt and 2 others like this.
  6. T.Jeff Veal
    Nice, great work as always.
  7. thewoodlands
    thewoodlands
    I took the Weed Eater to a trail the wife walks and after that was done, I did the same to the area I'm opening up for snow storage just off the corner of the driveway, I plan on having the two White Pine on the ground tomorrow.
    I did do a check of up top and that good size Maple that is down will need to be rolled down the hill after it's bucked up.
  8. Geoff C
    Geoff C
    NEPA
    Been splitting the load I got from a tree guy. I have 16 20” rounds to go.
  9. thewoodlands
    thewoodlands
    This is the big Maple that came down, I walked down from the top when I went for a ride today. I'm thinking the easiest way I can get this to an area I can split it will be rolling it down the hill.
  10. thewoodlands
    thewoodlands
    That's a very nice load of firewood.....testing the tires load!
    Chazsbetterhalf and T.Jeff Veal like this.
  11. T.Jeff Veal
    That size makes a nice amount of splits and not to bad to handle.
  12. T.Jeff Veal
    I hope it's solid enough to get some good wood from...
  13. T.Jeff Veal
    It pulls pretty good, felt like 5-6K on each load. It has better tires than the equipment trailer.
    Chazsbetterhalf and thewoodlands like this.
  14. Geoff C
    Geoff C
    NEPA
    I was actually going to edit my post to clarify but forgot. They are 20” long between 30-36” diameter. Makes a lot of nice splits but a bear to work with.
  15. thewoodlands
    thewoodlands
    Except for the top of the second Pine and some branches that I'll take over to the outside fireplace, this area will be ready for some snow storage this winter instead of being just off the corner of the driveway.
    I took two loads of branches and dead Pine over to the outside fireplace and then split & stacked all the Pine I had bucked up.
    The first picture is what it looked like before I took down three smaller trees the other day and two Pine today.
  16. T.Jeff Veal
    Fine job, you have it looking nice.
    thewoodlands and Chazsbetterhalf like this.
  17. thewoodlands
    thewoodlands
    Thanks T.Jeff Veal , I usually try and improve some of the areas we have for snow storage each summer/fall, I have two or three more areas that I plan on doing before fall. Even though I had plenty of trails around the house, the areas for snow storage started after we bought the tractor in August of 2016 and the driveway has been getting wider ever since.
    Of the two trees I felled today, one was dead and the other had some green at the top but was dying so they weren't good trees.
    T.Jeff Veal and Chazsbetterhalf like this.
  18. thewoodlands
    thewoodlands
    The wife would like this down but the widowmaker has me holding off and hoping a good wind or harsh winter would take the widowmaker down but it's been three years and it's still up there. 104_2133b.JPG
  19. T.Jeff Veal
    That is definitely a dangerous tree. Be careful, brother. If I HAD to cut it, I think I would fell it in the direction of the widow maker...
  20. thewoodlands
    thewoodlands
    That's the opposite way of the natural lean but a good idea, I'll see what trees if any are in that felling path. I've had some luck bringing those down with a shot gun and another that was just a waste of shells.
