Thoughts on a splitter vent issue?
Discussion in 'Chainsaws and Power Equipment' started by System, Aug 9, 2021.
  1. System
    System
    Western MA
    So, still really liking the Swisher 34 ton splitter. However, one thing I can't figure is this. It has a vent cap/ dipstick combo in the opening of the hydro tank. The venting part of it is the issue. If I'm setup at even the slightest incline, I get a lot of fluid out of the vent cap. It will also leak fluid when towing it around the lot with the atv from splashing. So, the vent part of the cap seems to be wide open as opposed to pressure open. I contacted Swisher who quickly sent me a replacement. The replacement does the same. The correct amount of fluid is in the splitter and I can't think of any cause other than overfilling.
    On my past splitters, there has been a different style of vent. My DHT unit had a square head with a small head in the side of it. My White had what looked like an old valve cover push in vent. Both would leak a little if at an extreme angle when splitting but this one is a faucet. Thoughts on a remedy? My ideas are to ether source a different style vent cap or raise the vent tube with a section of black pipe with a coupler on the end and use the existing cap.
    Here's the cap that's on it now:
  2. farmer steve
    farmer steve
    top of the hill york co. PA.
    Not familiar with the swisher units but just a question. Is the dipstick supposed to be screwed in or not when you check the fluid level? I ask this because it sounds like you may be over filled.
    T.Jeff Veal, amateur cutter and Horkn like this.
  3. System
    System
    Western MA
    Nope, not overfilled. With the dipstick screwed in it's at, but not above, the full hash mark. With it unscrewed it's in the middle of the range.
  4. System
    System
    Western MA
    I think I'm going to try the extension first. Perhaps, having it all the way "full" is not in its comfort range despite not being over on the hash marks. There are some better vent caps on Amazon too I could try but in the end, if the fluid is sloshing all the way up there, a better cap will likely leak too.
  5. brenndatomu
    I would, then maybe a larger vent cap too...how far down in the tank is the oil level? If the splitter is off camber enough to have the oil level close to the top of the tank at the vent area, some is probably coming out...if you park the splitter so the vent cap is on the "high side" of the hill, that'll help alot too...
  6. System
    System
    Western MA
    Yes sir, I usually try to keep it on the high side but I think the extension will give me some freedom in that regard. As I said, with past splitters I've had some spit from time to time but this one is so open that even towing causes it to slosh out. A quick google search indicates that I'm not alone. If the extension doesn't completely do the trick, Buyers makes a very nice metal venting cap that I could try too.
  7. Redneck
    Redneck
    Burton mi
    Put the oil level at the high mark with the vent / dipstick unscrewed ( just sitting on ) the filler tube.
    One of my splitters is very sensitive to the oil level. This took care of the spilling problems.
  8. brenndatomu
    The extension is not a surefire fix...if the oil level gets to the vent hole in the tank, often times it will just go ahead a spew it up and out...almost need an oil separator/vent cap in that scenario...you could make one with some pipe fittings....just need to upsize the pipe for a few inches, and then neck it back down to attach the vent cap. You can upsize off the existing with a bell type pipe reducer (like 1/2" (3/4"?) to 1.5 or 2") a 1.5 or 2" pipe nipple, then another bell type reducer to attach your vent cap...if that makes sense.
    NPT Threaded Bell Reducer | Dixon Valve US | World Class Customer Service
    Or you can just use pipe bushings in each end of a 2" coupling to accomplish the upsize too...
    amateur cutter, Horkn and Warner like this.
  9. System
    System
    Western MA
    That would actually put me higher as right now, it's at the high mark with it screwed in.
  10. Warner
    Man, that would really grind my gears!
    maybe a short npt nipple and a coupling? Would be petty cheap to try.
    amateur cutter likes this.
  11. System
    System
    Western MA
    I think the extension will get me some improvement to start. When splitting in the woods, I just don't like to always search for a perfectly level spot you know? But if it's coming out while towing and splashing around, that's just not ok.
    amateur cutter, Horkn and Ronaldo like this.
  12. System
    System
    Western MA
    Yup, that's exactly what I'm going to do. I may make it tall too. Perhaps 6" or so.
  13. Warner
    I was thinking the same thing but thought it might be goofy :thumbs:
  14. System
    System
    Western MA
    If 6" is goofy, maybe I'll go 8"... :D
  15. Redneck
    Redneck
    Burton mi
    Sorry it should be at the low end not full end.
  16. System
    System
    Western MA
    Got ya. I could siphon some out I suppose. Free to try...
  17. brenndatomu
    How much does it need extended until you could use it as a grab handle? :whistle: Now that would be goofy! :picard: :rofl: :lol:
    My brother had this issue on his homebuilt splitter, extending the vent didn't work in his case...up sizing the vent pipe for a few inches at the top right below the vent cap did though...
  18. System
    System
    Western MA
    I'm betting that removing a bit of fluid and a goofy extension will do it for $5. If not, I'll investigate further options. I appreciate your ideas!
    amateur cutter, Horkn and brenndatomu like this.
  19. Eric VW
  20. huskihl
    huskihl
    Where is the oil level at when it is hot and with the cylinder retracted?
