Two Days of Good Splitting, Finally
Discussion in 'The Wood Pile' started by barns1, Aug 3, 2021.
  1. barns1
    barns1
    Cedar Hill, Missouri
    Temperature and Humidity have been terrible, 90's and 90's, for quite awhile here, but the last two days have been good in the mornings. It was good to get the old splitter out and get some rounds split.
    Update on how the plastic lumber floor that I installed in my utility trailer/wood hauler is holding up. It's going on two years now and so far it has been excellent. I have had 7 to 8 logs at a time, 12-16" round, 4 to 5' long loaded (some dropped on to it) with no problems. No scuffs or gouges from dragging the logs off when I get them home. I was concerned when using it in below freezing weather that it might crack, but again no problems. It cost me close to $300 up front, but no more rotted floors to replace.
  2. amateur cutter
    We've had some decent weather here too & got some wooding done as well. Glad the trailer floor is holding up, that's good to know!
  3. barns1
    barns1
    Figured I better get warmed up (in shape) for this fall.
  4. Sirchopsalot
    Sirchopsalot
    medium city in CT
    It feels good to make progress on cutting splitting and stacking. Even a little every day, for a few weeks, gets a big job done.
    Good to hear wooding is happening!!
    Sca
  5. moresnow
    moresnow
    I've been splitting most mornings here as well. A couple hours very early is all I can take. We have had some very warm weather as well. I feel your pain:yes:
    MikeInMa, Chaz, Slocum and 2 others like this.
  6. Andimus Prime
    Andimus Prime
    NW NC
    Any pics of the floor?
  7. buZZsaw BRAD
    Its nice to have the drier weather for making firewood. Not a fan (no pun intended) of doing it in the heat!
  8. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Weather has been cooperative here as well the last several days. Too bad work hasn't. Calling for 90s next week:(
  9. barns1
    barns1
    I'll try and get a photo or two a little later.
  10. barns1
    barns1
    Here's a few photos of the plastic lumber floor in my utility/wood hauler trailer for you. I didn't notice the boards were different shades on the other sides of the boards until I already had several bolted down otherwise they would have been one shade of brown. What made it nice is that my trailer has metal angle bars across the boards front and rear. All I had to do was unbolt them, remove the old boards, cut the new boards to length and bolt them down, easy job. I also took the opportunity to Rustoleum brush paint the frame while all the boards were off. The trailer sits in the sun most of the day and I haven't noticed any fading either. Hope this helps.
  11. Erik B
    Erik B
    Western Wisconsin
    It has been fairly nice for splitting the past couple days. I finished all of the rounds I had in my processing area. I need enough wood to fill 2 pallets. I do have some blocks laying in the woods that I cut earlier this year. When I have some cooler mornings I will get it taken to the processing spot.
    Chaz likes this.
