Another Upgrade To the Skidding Operation.
Discussion in 'The Wood Pile' started by amateur cutter, Jul 17, 2021.
  1. buZZsaw BRAD
    Even better with a mini gun and maybe a 70mm cannon for good measure
  2. amateur cutter
    Plan is to use it in difficult areas to skid on jobs. It'll run on soft ground better than the mini & that's enough winch to unstick it if necessary. I'll make sure everything works good & then put er to work.
  3. Backwoods Savage
    How is the speed on the winch Adam?
  4. amateur cutter
    It's pretty good, I don't know in fpm, but it has high low & reverse. In high it's pretty fast.
  5. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I'm holding out for an armored snowcat!
  6. Screwloose
    Could have a waukesha in it.
    Man I'm jealous, first the skidder then the sweet ditch witch now this ?????
    Even with jealousy it couldn't have found a better home!!
  7. Canadian border VT
    Screwloose is right the man has skills and Toys!!
  8. Flamestead
    Flamestead
    Windsor County, VT
    Comparing photos, this looks like a model B (so a BG)? Tractordata says a Hercules engine, and says it is a 4-ton machine. Looks like fun!
  9. T.Jeff Veal
    Yep, you done gooder. That is a nice machine. Have fun and :ithappened:
  10. amateur cutter
    Correct on both counts after I found the tag in the paperwork. BG model Serial # 6C6414. First issue is track pads. They are not available. I may end up with steel grousers.
  11. Screwloose
    This can add up quick!!
