026 Project
Discussion in 'Chainsaws and Power Equipment' started by Kg461, Aug 2, 2014.
  1. Kg461
    Kg461
    Provencal, La.
    Just finished up on this ported 026 complete redo project. Installed a 16"es 3/8 bar with a oregon lgx full comp. Converted this chain to square chisel and I must say it cut very good. Anyone else converted 16" chain to square chisel and whats your opinion of how it cut? 20140802_002611.jpg
  2. foragefarmer
    foragefarmer
    Central, Virginia
    More pictures please. Welcome to FHC.
    clemsonfor and HoneyFuzz like this.
  3. StickBender
    StickBender
    Clean!
    HoneyFuzz and Kg461 like this.
  4. Kg461
    Kg461
    Provencal, La.
    Thanks! Ill try and do some videos as soon as possible 20140718_104055.jpg 20140718_104055.jpg 20140730_070119.jpg 20140802_002546.jpg
  5. HittinSteel
    HittinSteel
    Wooster, Ohio
    Welcome and very nice saw.
    This makes me miss my 260. Great solid saw :)
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Welcome. Thats a sweety of a saw there :). Look forward to hearing more about it !
    Chvymn99 likes this.
  7. DexterDay
    I Love (READ: LOVE) how you did the 026 tag up front. An old school tag up front and Pro sticker in the back!!
    Welcome to FHC Keith! ! Glad to see your face (avatar) over here :thumbs:
    I look forward to a video of that saw! Great looking rebuild! My hat is off to you sir!
  8. cnice_37
    cnice_37
    New plastics? That looks absolutely cherry.
    Is that mesh your own addition or standard?
    Welcome to FHC!
    Kg461 and HoneyFuzz like this.
  9. clemsonfor
    I think that mesh was standard on 026?
  10. clemsonfor
    Never mind I zoomed in the pic thats not factory. That looks like window screen in there
    HoneyFuzz likes this.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Why do I want an 026 Pro now ?? :) LOL
  12. Kg461
    Kg461
    Provencal, La.
    New bottom end bearings, seals,gasket, ported mahle cylinder, meteor piston and rings, modded muffler, new ignition coil and wiring, new clutch and bearing, new bar studs, new 16" es bar with oregon lgx chain filed square, new stihl clutch cover with captive bar nuts, advanced timing, wt194 walbro rebuilt, new plastic with metal nameplate. Painted crankcase, new starter spring and pawls and the screen on top between covers I added
    Chvymn99, cnice_37 and HoneyFuzz like this.
  13. Kg461
    Kg461
    Provencal, La.
    Not window screen. Stainless heavy gauge that I use in mufflers that Mastermind recommended
    DexterDay and HoneyFuzz like this.
  14. DexterDay
    That is MS 260 plastic with an 026 badge and I must say I love it. Not having the name plate in the traditional spot, or the Pro in the traditional spot looks great.
    Normally, the Pro is up front by the 026 badge, and the badge is where the Pro is. But an 026 had a flat top, to accommodate the insert in the back. The 260 has the number on the recoil cover. So they made the top round (just like they did with the top to the 360)
    Great saw!! Love it!
    How did you affix the screen? That's a great idea on any older Stihl that does not have the new filter technology.
  15. Kg461
    Kg461
    Provencal, La.
    Dex that took some engineering! Lol! On the air filter housing I dremeled a channel all the way around for the screen to slide into and shaped the screen. I then put the standard wire cover back on and it holds the screen in place really well. I left about an inch of screen to extend under the front cover so You have to put the filter housing on first and then the top cover
    DexterDay and cnice_37 like this.
  16. swags
    swags Moderator
    Saws looking great, the 026 is a great little saw. That is the saw I use almost all the time around home and usually the saw I pick up to do any limbing after felling
    clemsonfor, DexterDay and Kg461 like this.
  17. clemsonfor
    An 026/260 is on my want list wearing a 16" bar.
    Kg461 and swags like this.
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Very nice work, I want to ask where you got the screen you used. I am in the process of buying an old Poulan that needs a bit of it to keep critters out of the EP, saw was not manufactured with a muffler!
    clemsonfor likes this.
  19. Kg461
    Kg461
    Provencal, La.
    Ebay and I think its called 304 stainless?Amazon has it and its called 304 stainless mesh screen
  20. Kg461
    Kg461
    Provencal, La.
    20140806_090451.jpg Added a tach to handle and a orange screwdriver behind handle for onboard manual mtronics!!! Lol. Testing 87 octane tomorrow vs vp94 in the 026 ported by myself and testing it also in the 362c Masterminded
