Ran my 290 and ruined a chain
Discussion in 'Chainsaws and Power Equipment' started by firecracker_77, Aug 3, 2014.
  1. firecracker_77
    firecracker_77
    IL
    I brought my 290 out to play. It hadn't been run in 10 months or so, and fired right up with old gas. :whistle:
    Was really enjoying that saw with the 16" bar. Much lighter than the 25" bar combo that I had gotten used to on the 441. On smaller stuff, I still love this saw.
    Anyhow...was cutting up an old picnic table when I inevitably hit a metal bracket while not paying attention. Needless to say the chain needs time on the sharpener. Makes me mad too...was cutting great immediately before that. My other 16" chains weren't with me, so I had to shut down for the day. :headbang:
    It's really nice btw to put the 16" chain on a bar compared to a 25". Almost effortless!
    The 441 might be getting a really small bar for noodling and smaller stuff. I am in the minority on here, but I love the Farm Boss. It gets a bad rep as anemic and weak, but it does have it's virtues, and I won't be getting rid of it anytime soon. :p
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Bummer :(
    firecracker_77 and Chvymn99 like this.
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    Sounds like Murphy was hanging around with you.
    firecracker_77 likes this.
  4. DexterDay
    The 16" bar on your 290 will mount right up to the 441.
    What size bar are you looking for?
    clemsonfor likes this.
  5. Chvymn99
    Sorry to hear that, but you never when chit happens... But yea your correct on the 290 they are a decent saw that gets a bad rep.
  6. firecracker_77
    firecracker_77
    IL
    If I can find the bracket and it didn't make it's way into the fire, I'll post a pic. Took a pretty good bite out of it.
  7. firecracker_77
    firecracker_77
    IL
    Really? That's good news. The chain size is different though. Does the same bar rail work with different chains? .325 versus the .375?
    16" is a great size for little stuff. Keeps the weight down, quick to sharpen, and fast to swap chains.
  8. DexterDay
    Nope. Never mind. If you have .325 on the 290, then it won't work. The rail tip won't match up for a 3/8".
    But, you can buy a 16" in 3/8" and then change your 290 over to a 3/8" drum and/or rim sprocket? That's pretty cheap. If it has a rim already, it's less than $8.
    clemsonfor and firecracker_77 like this.
  9. MasterMech
    Call me crazy but I'd buy a .325 9 pin rim for the 441 and run that 16" bar and chain from the 290 on it just for chits and giggles.
  10. DexterDay
    That does sound like fun... And it would be cheap.
    clemsonfor and MasterMech like this.
  11. firecracker_77
    firecracker_77
    IL
    LOL!
  12. clemsonfor
    You burned the picnick tableo_O
    Hope you were upwind and no one was down wind:eek:
    That sounds fun MM to run the .325 on the 441!
    I swapped my near off my 390 to my 650 but its only a 20". Be cool to have a light saber 16" for fun!!:D
  13. firecracker_77
    firecracker_77
    IL
    Does that increase chain speed? That picnic table was very weathered and had no finish on it, so there was no black smoke.
  14. clemsonfor
    You sure there was no arsenic in it from treated wood?
  15. clemsonfor
    [quote="firecracker_77, post: 127717, member]Does that increase chain speed? That picnic table was very weathered and had no finish on it, so there was no black smoke.[/quote]
    No but maybe a bit from less drag..it just dosent put as much drag on the saw from having a shorter bar and less cutters cape able of being in the wood.
    Chain speed is set by the saw engine rotation and the sprocket. The chain will go the speed on each bar cause the saw is going to turn X RPM regardless of the bar length.
  16. DexterDay
    It was a picnic table..
    Not a 2 story house with a wrap around deck ;)
  17. clemsonfor
    Your body your lungs.
    I am pretty lax with some stuff..like exposer to dust and exhaust or used oil. But things that can deffinitly poison or kill you not so much.
    That said some plastic or a small treated cutoff has made it to my burn pile before but not usually.
  18. DexterDay
    What MasterMech suggested? Yes. That will increase chain speed.. Severely
    MasterMech likes this.
  19. DexterDay
    Your not getting the point I guess?
    It's a picnic table. A very small amount of wood.
    When compared to a house, or another building that may have a lot of pressure treated wood (why I said a wrap around porch ). Numerous people downwind of those types of fires and can do little to nothing about it.
    And, not all picnic tables are treated lumber. Most sold around me are just regular lumber.
    Anyway, enough highjackin.. You wanna talk Arsenic? Start a thread. :)
  20. clemsonfor
    Yes that scenario does.
