Seasonal activity
Discussion in 'The Wood Pile' started by MikeInMa, Jul 3, 2021.
  1. MikeInMa
    As in, woodstove maintenance.
    I had the chimney sweep here yesterday. I had removed the stove top (4 corner bolts) so he could vacuum everything. Maybe a heaping handful of creosote. About average to past years. A 14ft of straight stove pipe. He said it all came out. Nothing sticking to the inside. :yes:
    I got a new catalytic combuster and put it in. Having the top off allowed me to check on various gaskets. I usually need to cement some that are loose. All looked good, this time around.
    Here's a link to a sticky, in case you haven't read it.
    Tis the season for inspecting your set-up!!
    Stay safe people!
  2. M2theB
    M2theB
    Central Massachusetts
    just made plans to do the same.
  3. Backwoods Savage
    I still plan on doing ours but it may have to wait a while as my body is just acting up too much.
  4. Chvymn99
    I'll do mine in the fall before fire up time... But after reading your thread, got me to thinking as I was mowing grass ... I looked up at the cap, it was clean still... I've got the screen cap, used to have issues with clogging up the small screen... so the last two caps (last one blew off in a 80 mph wind storm).... I took and cut those screen holes bigger but not too big that birds can get in... and put two screws in it... :rofl: :lol:... and fastened the pipe to the roof top....:D
  5. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Im behind this year for whatever reason. Just slacking on all fronts. Need to clean the chimney and stove, 3 cord of rounds that need split and stacked, grass and trees growing around and over my stacks, pile of junk pine sitting in the middle of my stacking area that needs burned, need to cut a scrub tree and brush to make room for 3 more cords . I better get on the ball before my FHC membership is revoked.
  6. Ronaldo
    Ronaldo
    This summer I had water dripping in around the stove pipe during heavy rains. Found the problem upon closer inspection. Evidently snow pack slid down and did the damage on the flashing. Got the new flashing and will install it soon. I should be ready for heating season after that.[​IMG][​IMG][​IMG][​IMG]
  7. MikeInMa
    Good catch!
  8. mat60
    mat60
    ME
    I thing there may be something you could install on your steel roof above the chimney so it doesnt happen again.
  9. Ronaldo
    Ronaldo
    Yes, there is a triangular type of guard that diverts snow around the flashing and chimney. The strange part is that I've had this set up for 20 yrs and never an issue. We didn't really have any more snow last winter, so......
    Maybe the conditions were just perfect this time??? Or bigfoot was up there stomping around?
  10. mat60
    mat60
    ME
    Got to get after my chimney cleaning this fall. Good reminder MikeInMa
  11. BuckeyeFootball
    BuckeyeFootball
    I still have ashes in my stove I should probably get on that.
  12. MikeInMa
    Maybe ice accumulated.
