sweeping on a peak
Discussion in 'Everything Else (off topic)' started by Sirchopsalot, Jun 25, 2021.
  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    So our first sweep was today.
    We burned from January till June.
    Generally the chimney liner and cap weren't as bad as I've seen in sweeping videos...
    After all, our neighbor didn't even know we burned this winter!
    Either way, our chimney is at the very peak of the building. The roof is rather steep, and footing not awesome. If I had something better to stand on, I'd have done a better job of it. And unless there is an easier way, I'm not sure how long Ill do this for...and certainly not in colder weather.
    Is there a better way of climbing up and down the roof, a better platform to work from once up there?
    Thinking along the lines of a permanently attached ladder, or cleats and wood for standing on, permanently attached.
    Sca
  2. brenndatomu
    What's your setup like?
    Good chance you can clean from the bottom up with a SootEater...
  3. Backwoods Savage
    I agree that climbing on a steep pitched roof then trying to work is no fun. A soot eater like brenndatomu mentioned would make things easier, depending on your setup. Otherwise a lift sometimes is in order. Hopefully you keep burning clean and only have to clean occasionally. This is where a good burning stove is great (if run right) and naturally, the best dry wood to burn.
  4. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    When I have to work on steep shingle roofs I use foam rubber cushions salvaged from furniture. They don't slide and protect the roof.
  5. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Unfortunately no. The liner is capped just below the thimble, and that is 12 feet above the cleanout in the basement.
    Soot eater doesn't recommend going in from the thimble as the angle would be pretty sharp.
    Sca
  6. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Getting up there was not an issue, but standing right on the peak was more doing than I like, also don't want to squash the ridge cap standing there cleaning out over the years.
    Getting down was easy enough with a rope...so need to expedite that process with something I can hook up and unhook more easily.
    So mounting a ladder to the roof, would be an option, as would fixing some sort of platform to stand on....perhaps not to leave there, but that I could bring up and use w/out damaging the roof.
    The stuff coming out of there was dry fluffy stuff, pretty straight forward cleaning.
    Sca
  7. Warner
  8. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I use the ladder hooks too for inspecting or roof work. Extension ladder to above the gutter and single ladder section with hooks to peak Cordless screwgun too beats cord.
    I'll be bottom up for cleaning now.
  9. fishingpol
    fishingpol
    I made this rig last fall for bath vent termination install. Dicey, but it was secure and ratchet straps help.
    MikeInMa, Sirchopsalot and Eric VW like this.
  10. Eric VW
    Looks OSHA approved to me... well at least OHSh!T approved.
    :whistle:
    :salute:
  11. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Im kinda wishing they left the bottom open so I could reach it from the basement. Until the liner is replaced, I'm top cleaning.
    I might just make a rope ladder to use to walk up the roof. Maybe loop the end around the chimney, and set it there. That would get me up and back 1x or 2x a year. The wind won't blow it around too much. (I can always throw a loop of 550 around a handy vent stack to keep it from blowing up over).
    Still mulling on some sorta platform to build, and lug up there and set up. Shouldn't leave it up there, and not interested in trying to anchor it by drilling holes...
    Sca
  12. Softwood
    Softwood
    Central WI
