  1. JackHammer
    JackHammer
    Yeah, if they get it right they will. If they get it wrong, they lose their house.
    savemoney, bogieb, eatonpcat and 5 others like this.
  2. mat60
    mat60
    ME
    The trim and paint are making a big difference.
  3. wildwest
    Wyoming high plains
    I'm not sure, it's one of these buildings, unless that's the front and back of the same building:
    savemoney, eatonpcat, Horkn and 4 others like this.
  4. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Ah. Big spot.
  5. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Thanks, once the last wall is sided and the soffit is on it'll look more or less complete even if there's a few details left. Then the skirt, that'll be the last big job
  6. wildwest
    Wyoming high plains
    I bet you were laughing all the way to the bank, awesome garage for your sweat equity in collecting and disassembling those pallets :)
  7. mat60
    mat60
    ME
    Keep up the good work. :yes:
  8. wildwest
    Wyoming high plains
    This makes me smile every single time!
  9. mat60
    mat60
    ME
    :rofl: :lol::rofl: :lol: It just did me to.. That was good.:)
  10. Warner
    12404E80-3D2F-4612-B1E6-8BD1E00D064F.jpeg This is gonna dip into the new boat fund:mad::mad::mad::headbang:
  11. JackHammer
    JackHammer
    What are we looking at here? Are those exterior steps?
  12. Warner
    Yes, exterior steps off a front porch. Unfortunately the fact that water was going to constantly drip off the metal roof onto the steps was not accounted for during design. It was a problem I knew about when we bought the house but got real bad recently. It’s going to be a can of worms.
  13. Canadian border VT
    I did that once went to replace a window on back porch. Sunk a 5” screw driver right through a 4x4. That was supposed to be structural .:jaw:
    ended up cutting 2 feet off deck floor and rebuilding!
    A lil :emptywallet: Turned:makeitrain"
  14. wildwest
    Wyoming high plains
    I'm looking to buy a portable swamp cooler, 95* and 100* in black asphalt parking lot. One on sale has computerish buttons and a remote, holds 7 gal, CFM and dB not listed. I'm looking really hard at this one instead, it holds almost 5 gal, 1300 CFM, and I like the idea of a knob instead of electronic buttons. Any thoughts?
    PS, we have a window A/C, but the only window for it is across from me and I freeze.
    mat60, Chazsbetterhalf, Horkn and 2 others like this.
  15. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
  16. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Had to replace a faucet at work today. Only a handle was broke, but the mounting system for that handle seems to be obsolete so had to get a whole faucet. One of the plastic wing nuts that hold on underneath would not budge for me. I had to bend and break the whole thing apart, pry it loose enough that there was a small gap between the sink and that wing nut. Then I had to keep snapping pieces off the wing nut till it was broken enough to pull up through the mounting hole.
  17. JackHammer
    JackHammer
    I feel like this is how 99% of my home repairs go. Fix a handle, the pipe fitting cracks and then you need a new fixture, fitting, and 15 ft. of pipe.
  18. TrinitySouth99
    TrinitySouth99
    New Harbour, NFLD
    Sure seems that way at times, don't it? I find the same sometimes but more so just that if the job seems like it should take a half hour, it turns into 2 hours
  19. bogieb
    I would go with the manual control - less to break. I would also go with one that can cool more sq/ft than you think you need. They are giving you max ability - and sometimes they round up or take a bit of liberty as well as cite for perfect conditions. If you need 500 sq/ft, raise it to 700 sq/ft (or 900). Of course, you may only need it to cool 200 sq/ft, and in that case, that one would be good.
  20. savemoney
    Good day from Maine!
    I lost 10 lbs so far. Trying to move more and do more, eat less.. Not easy.
    bogieb, Stephiedoll, Horkn and 14 others like this.
