1976 Stihl 020AV restoration project
Discussion in 'Chainsaws and Power Equipment' started by Smaug, Jun 7, 2021.
  1. Smaug
    Smaug
    Lake Toxaway, NC
    Howdy...
    I recently went up to Connecticut to visit my Dad for the first time in way too long.
    While I was visiting, I got all the old mowers, and small engine machines running, and did a few days worth of work around the property.
    But upstairs in the barn, I found the old Stihl 020AV chainsaw that we bought whern I was seven years old. It didn't run, but it turned over smooth. It's old, and dirty, and the fuel inside was thick and dark, but this is the first chainsaw I ever used. I have more hours and memories with this saw than any other, as well as the burn on my right thigh from the time I rested the side facing muffler there while wearing shorts one hot summers day.
    So I brought the power head back home with me where I have a decent work bench and tools.
    My goal is to restore this saw, and give back to my Dad later this summer.
    I'll update this thread as I make progress.
    I'm looking forward to this.
  2. buzz-saw
    buzz-saw
    Ct.
    Great project for sure.
    I'm sure that he will really appreciate it when done. Funny how those memories just stick in your mind.
  3. Backwoods Savage
    I'll bet your Dad will be surprised and very happy.
  4. buZZsaw BRAD
    I bought a circa 1973 rear handled version of the same. M2theB restored it. Maybe he can chime in with what he did as i forget. He also is doing my circa 1992 026.
    Connecticut? What town? Shouldve PMed and we couldve met up!
  5. M2theB
    M2theB
    Central Massachusetts
    It’s a little bit of a puzzle in the right sequences.
    But once you get it down, it’s not hard, just tedious
    Brads saw had a very similar tank muck, and the impulse line was off and the carb was gummed up with the tank mud.
    Check for spark first.
  6. Smaug
    Smaug
    Lake Toxaway, NC
    I grew up in Litchfield county in the north west corner of the state. Haven't really been home in over 15 years. Sure was pretty to see again.
    Got the saw home and checked for spark. Check! :thumbs:
  7. Smaug
    Smaug
    Lake Toxaway, NC
    So far the gas tank is clean and rust free. All the rubber parts are supple and seem to be in good shape.
    But now the 020 needs a cleaning.
    First, remove handles.
    As you can see, it has been well cared for...
  8. Smaug
    Smaug
    Lake Toxaway, NC
    Now, get the case in half...
    and there's 30+ years of sawdust and oil.
    Looks like I've got some cleaning to do.
    Oh well, its therapy for people like me.
    I'm good...
  9. Smaug
    Smaug
    Lake Toxaway, NC
    Oh hey, I thought this was interesting.
  10. buZZsaw BRAD
    Nice country up that way. Im in lower New Haven county...North Haven.
  11. buZZsaw BRAD
    I traded a circa 1980's West German made 024 back in late April. Traded up for an 036 Pro
  12. Smaug
    Smaug
    Lake Toxaway, NC
    I've made a little more progress.
    The carb is out, and cleaned up a bit. I've ordered a rebuild kit for it which should be here next week.
    The carb is a Tillotson made I'd Toldeo Ohio. USA. That's pretty darned cool.
  13. Scotty Overkill
    I'd recommend, while its torn down, that you replace the crank seals. Yeah, it's more work, but in the long run it'll give you certainty that you have vacuum and no air leaks.
    Seals that sit around for decades become dry and brittle. It'd be ashame to have that thing down that far apart and put it back together only to find you need to year it down again to replace the seals.
  14. Smaug
    Smaug
    Lake Toxaway, NC
    Thank you for the reply and knowledge.
    I'll look into crank seals.
    (Are they just ill-tempered regular seals, or are they special?)
  15. Smaug
    Smaug
    Lake Toxaway, NC
    While waiting for for carb rebuild kit, I replaced the pull cord...
    I remember working at a rock climbing type store at the time, and this thick orange cord was all I could come up with at the time. It worked, but the action of the reeling in of the cord didn't feel right. IMG_20210622_49210.jpg
    Now remember, this was before the internet and all this techno wizardry we now take for granted when ordering parts for obscure European engines.
  16. Smaug
    Smaug
    Lake Toxaway, NC
    I replaced the fuel filter and internal tank fuel line.
    Check out this tan powder that was in the base of the fuel filter.
    I'll probably find more of this in the carburetor...
  17. amateur cutter
    I will say that that's a nice old saw & good for you for restoring it. I have one that was given me in running condition & I use it on occasion. I love those old saws. Enjoy the process!
  18. Smaug
    Smaug
    Lake Toxaway, NC
    So I took the carburetor apart and replaced the gaskets and diaphragm.
    I took the L and H needles out and used carb cleaner to get all the openings cleaned out.
    After everything in the carburetor was put back together, I decided to reassemble the saw and see if it would run.
    After about 50 pulls, and a couple of rough starts and brief moments where it did run, I broke the starter cord... :confused:
    I'll mess with it again later.
  19. amateur cutter
    Pour a little mix right on the air filter & fire it up. Way better on the shoulder & starter. They'll usually fire on one pull.
    Screwloose, metalcuttr and Smaug like this.
  20. M2theB
    M2theB
    Good to know there’s spark.
    How’d the screen to the metering valve look?
