I Bought a Hemi Hybrid
Discussion in 'The Wood Pile' started by amateur cutter, May 26, 2021.
  1. amateur cutter
    Found this about an hour north of me and had to have it. Home built & solid, runs and works well. 20210526_195932.jpg 20210526_200018.jpg 20210526_195945.jpg 20210526_200006.jpg
  2. thewoodlands
    thewoodlands
  3. amateur cutter
    I plan to pull it in the shop tomorrow after work & change the oil & give it a good look over. We'll put it to work this weekend & see how it does. I ran it briefly in the guy's yard to verify operation & hauled it home.
  4. Backwoods Savage
  5. The Wood Wolverine
    Splitter itself looks good. I'm not a fan of the engine cover.
    Horkn, OhioStihl, Chvymn99 and 3 others like this.
  6. brenndatomu
    The only thing he missed on that built is the 6" chrome stacks out the top! :thumbs:
    Interested in hearing how it actually works...
    Horkn, jo191145, Chvymn99 and 4 others like this.
  7. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I take it he was a Chevy fan.
    Softwood, Horkn, Chvymn99 and 3 others like this.
  8. Slocum
    Slocum
    North Central Indiana
    That’s cool. Curious to how hot the hyd oil might get. Don’t look like much oil capacity
  9. amateur cutter
    Right lol. I guess he owned an auto body supply.
    I'm wondering that too, we'll see. May add another tank.
  10. lukem
    And a Z71 sticker. Can't be a real redneck without one of those.
  11. Warner
    Can say as I ever seen an oil pan used as a good before...
  12. Chris F
    Chris F
    Micksburg, Ontario
    Wow, I completely missed the oil pan! That's quite the engine cover alright. What's underneath it for an engine?
  13. amateur cutter
    20HP Kohler Magnum. He just cut the front 1/2 of a lawn tractor off & used that as the engine mount. The oil pan "hood scoop" cracked me up, but it looks kinda cool. I changed the oil & filter & messed with it a bit after work. It seems to work well, no apparent issues. The log lift comes up past 90 degrees & will interfere with the push plate, so I gotta put a stop in the cylinder & turn down the flow to the cylinder a bit. It's got a decent cycle time & shorter stroke than my rugged split at only 24" so it should make campfire wood quicker without having to use a stroke limiter. It's pretty well built I think. For $ 600.00 it won't take long to pay for itself.
  14. buZZsaw BRAD
    Does it have solar panels if the engine fails and the battery goes dead? Cool looking machine there AC. How many ton you think?
  15. Canadian border VT
    My question is does log lift work??
  16. amateur cutter
    Ha, no solar panels lol. Judging by cylinder bore & pump I'd say 35ish ton. Way more than necessary, but it is what it is.
  17. amateur cutter
    Sure does, I gotta limit the stroke & speed though. somebody broke the flow control valve on the lift & it comes past 90 degrees so it can get tangled up with the ram. If it pans out I'll add a log stop & catch tray to it as well.
  18. jo191145
    I see a box wedge in your future.
    Nice grab.
  19. Skier76
    Skier76
    CT and SoVT
    At first I thought it was propane powered! Then I saw the other pic with the lines running to it. Cool machine; nice score! Keep us posted on how it looks once you give it a once over.
    amateur cutter likes this.
  20. amateur cutter
    Did that yesterday, pretty solid machine. Needs a couple little tweaks, but it was cheap & should speed up splitting around here. 40F & sideways rain here today so it won't get run till tomorrow. I've got tree jobs to look at today.
