Echo 590 start/running issues?
Discussion in 'Chainsaws and Power Equipment' started by makey98, May 14, 2021.
  1. makey98
    makey98
    Have a Echo timberwolf that I have had for 3 years or so. I got about 4 cords of big diameter logs dropped off a couple years ago and ran that hard for a couple months and then occasional light use since then. Recently my new neighbor owns a tree service :) so he dropped off a bunch of big logs and filled my trailer up!! Worked on about 1/4 of it for 3 hours or so of cutting and then the next weekend ran for about 30 minutes and filled up gas tank and saw kept starting and then dying. I thought the mixed fuel was bad or maybe not the right ratio because it was the end of the can so got fresh fuel and fresh mix and had similar issues. Ran for 10 minutes or so then randomly died in the middle of the cut. Saw would start and then immediately die at idle. Any thoughts on where to start? Filter clean, saw recently cleaned and sharpened and new fuel...that is about my extend of mechanical ability. Help welcome!
    M2theB, brenndatomu and mat60 like this.
  2. Rothk
    Rothk
    WVA
    sounds to me like a carb damaged by ethanol fuel
    M2theB and mat60 like this.
  3. Canadian border VT
    5 year consumer warranty bring back to dealer???
  4. thewoodlands
    thewoodlands
    My Stihl 310 would run for 20 minutes and die while cutting, I took it over to two Stihl dealers and both said it was fine. The first dealer looked at it 3 or 4 times, it's fine, the second dealer looked at it once, it's fine. Each time I would bring it home and run it in a log and it would quit after 20 minutes, it pizzed me off so much I bought a new 311.
    After getting the 311 I bought a part saw with a newer carb in it, I put the newer carb in the 310 and it's still running fine.
  5. makey98
    makey98
    Interesting. I called to see how much a new carb was and it was $137!! ha. 1/3 of the price of what i paid for the saw... Shop said i could take it off and they will run it though ultrasonic cleaner for me for a small fee. Might try that to start.
  6. thewoodlands
    thewoodlands
    I hope it works.
  7. Rothk
    Rothk
    WVA
    Wow, that's expensive for a 2 stroke carb! I'm gonna try my best to keep the carb clean on mine.
  8. makey98
    makey98
    This is what I got going on, so can't afford a down saw. Never thought i needed two, but ........ probably should :) The dog is Bailey, she is my wood cutting buddy.
    Loon, Ron T, Jeremy Anthon and 5 others like this.
  9. M2theB
    M2theB
    Central Massachusetts
    hardly ever see a carb that needs to be replaced unless it’s been sitting in a cellar and got pitted. A good cleaning , ultrasonic is good, and a new kit, ($12ish),fixes most carb issues.
  10. makey98
    makey98
    Took the whole thing and left it with them because still under 5 year warranty. Been 8 days..... said it was the intake bellows? Apparently separated from the plate or something so allowing too much air in the carb. Should be done by the weekend. Need another saw so I don’t have to be down for so long... question is 500i or 472. Want to give Stihl and gander. The echo is fine and the price point is great but the heart wants what it wants....
    Chud, thewoodlands and M2theB like this.
  11. thewoodlands
    thewoodlands
    M2theB, Ron T, Sandhillbilly and 2 others like this.
  12. Chud
    Chud
    Yes, it’s good to have a small, medium, large saw and backups for each. One saw for each commonly used bar size is nice too, so you don’t have to waste time swapping bars. Just grab and go. Dull chain, no worries, you have backup saws to keep cutting.
    M2theB and Sandhillbilly like this.
  13. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    And after 3, ..., things escalate pretty rapidly :whistle:
    Stephiedoll, M2theB, Ronaldo and 2 others like this.
