Another New Felling Technique?
Discussion in 'The Wood Pile' started by buZZsaw BRAD, May 11, 2021.
  1. brenndatomu
    Gonna be a Darwin award beaver!
  2. buZZsaw BRAD
    I have no idea what or how he was doing it. The notch was where the back cut was and we had hoped the tree didnt fall backwards not that it wouldve caused any problems. Im glad i didnt see it happen.
  3. buZZsaw BRAD
    Ran a tank and a half through the 500i bucking the trunk up. Raised off the ground which was a huge plus. What branches were left shattered on impact. Ran the 25" bar with full skip. Dead white oak some hard stuff. IMG_4931.JPG IMG_4934.JPG IMG_4933.JPG IMG_4932.JPG
    Ill switch to 22" bar and cut more tomorrow.
  4. Stihl Kicking
    Stihl Kicking
    Missouri
    That is some good looking wood!! As dead as it was, it may be ready in a year.
  5. BuckeyeFootball
    BuckeyeFootball
  6. Backwoods Savage
    Well at least Brad got some great firewood.
  7. buZZsaw BRAD
    i didnt put a MM to it. If i remember maybe today Seemed a lot drier and had only a faint aroma compared to fresh cut. The tree has been dead at least three years as i felled a dead one close by in September of 2018. Between him and the neighbor there's maybe a dozen dead ones in their back woods.
  8. buZZsaw BRAD
    Actually i dont want any. My friends PA is 100' away through the woods. Its all for him
  9. Backwoods Savage
  10. Firewood Bandit
    Firewood Bandit
    Oh my, that stump!
    However in order to add something that can be constructive. A very experienced class III feller tutored me. He had advice that most would not think of. If you start felling a tree and you really screw up the hinge/ back cut or both just STOP before the tree gets unstable. Abandon the cut and just redo it correctly above in sound wood.
  11. buZZsaw BRAD
    He originally had the notch on the felling cut side with just a kerf where the notch should have been. (the tree fell in the correct direction)
    Nice that you got an education from a pro.
    amateur cutter, Horkn and MikeInMa like this.
  12. jrider
    jrider
    Good thing you don't have to worry about hauling those big rounds out of the woods...PITA!
  13. buZZsaw BRAD
    True. Cant even drive through the yard as its squishy. I got stuck in his yard three years ago doing the same. Look carefully at the OP pics and you can see his PA in back.
    Also my reasoning for not felling the others in his woods
    amateur cutter and Horkn like this.
  14. Joe P
    Joe P
    Wisconsin
    Good Lord. I beat myself up if the back and front of my hinge wood isn't parallel. Thanks for posting this. I feel much better about myself now :p
  15. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Perhaps how he got the limp to begin with...
    Whats PA? Not in our outdated glossary here....
    Sca
  16. Horkn
    Yep..
    I was going to ask if buZZsaw BRAD 's friend was an actual beaver. Because that's sure what it looks like to me.
    Glad that nobody got hurt, because that stump looks like someone died.
    buZZsaw BRAD and amateur cutter like this.
  17. Horkn
  18. Canadian border VT
    Probably processing area..
  19. amateur cutter
    Yep, that's how I was taught as well, & I ain't too proud to admit I've used that technique a time or two, much safer.
    Brad, crawler tractor with a winch, 1.5k per tree removed & cleaned up and you could pay for the tractor.:p
  20. amateur cutter
    If this gets stuck you just hook a tree & pull yourself out. 20210821_124309.jpg
