Wanna Talk About Port Shapes?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Jul 30, 2014.
  1. Mastermind
    Mastermind
    Tennessee
    We talk a lot about compression, port timing, muffler mods, etc. We don't talk too much about the shape of the port, and how the shape relates to performance.
    Here's a few pics of an 064 I just did.......and there's some pics of another 064 jug in here too. I sanded through the plating when I was getting the transfer off the second 064 jug. :(
    This pic really shows the difference between a "performance shape" and a stock port. Notice how the corners have been opened up to increase time area.........but the port height is unaffected.
    In this pic the rough in of the intake port is nearly complete......I'll tighten the corners a little more and work on out to my marks. Notice that this port is only a little wider than stock, and at the stock height. It should be plain to see that this port will be more conductive to flow than a stock port.
    Here is a stock 064 intake port for comparison.
    And here they are side by side.
    $ooline, Deacon, GRIZ and 9 others like this.
  2. Mastermind
    Mastermind
    Tennessee
    Now, for the transfer ports.
    Here's a shot of the stock ports.
    And here's a fully finished transfer.
    Notice the corners. They are even tighter than the intake port. When the transfers first crack open, you want to be fully flowing across the entire area of the port.
    Here's another shot that shows how tight the corners are......and that shape is carried back into the port a good ways.
    Here's another......note the lower opening of the transfer. I don't open this down as far as I once did. I just take the lip off to prevent fuel puddling.
    $ooline, Deacon, GRIZ and 4 others like this.
  3. Mastermind
    Mastermind
    Tennessee
    Same treatment on the exhaust port.......just raise it to the height I want, and tighten the corners up a bit. Not as much as on the intake though. The rings ride across the exhaust port so you want a nice arch to the port to keep from beating the rings up.
    Here's another thought. In a two stroke engine, it's all about the time/area of the ports went it comes to performance. You can widen the port to gain T/A, or you can raise it. If the rings travel across the exhaust would it be wiser to get the T/A you want by setting the height, or widening the port?????
    $ooline, GRIZ, splitoak and 3 others like this.
  4. Mastermind
    Mastermind
    Tennessee
    Here's the last pic I have for now.
    I don't normally enlarge the exhaust flange area on these saws. It's plenty big enough. I just deburr, and smooth it out. It's more important the match the muffler, heat shield, and gasket to the jug perfectly than it is to hog stuff out and weaken the flange.....
    Note the arch across the roof of the exhaust port.........easy on the rings is key here.
    $ooline, GRIZ, PullinMyPoulan and 5 others like this.
  5. HittinSteel
    HittinSteel
    Wooster, Ohio
    Perfect thread since some have been asking about what porting is. Ill be watching and admiring.
    What tools do you use for grinding Randy?
    $ooline, DexterDay, HoneyFuzz and 2 others like this.
  6. Mastermind
    Mastermind
    Tennessee
    A picture is worth quite a few words here Bryan. :)
  7. HittinSteel
    HittinSteel
    Wooster, Ohio
    What would you recomnend for someone that just does a few muffler mods now and then? Ive destroyed dremels and the cheap HF knockoffs (they actually lasted longer).
    I cant justify a foredom setup like that!
  8. MasterMech
    Hey Randy, what's up with the small connection between the upper and lower transfers? That's not something I've seen in many of your photos, so why on this saw?
    If I may hazard a guess, you are trying to get the transfers flowing a bit sooner by shortening the flow path?
    clemsonfor likes this.
  9. mdavlee
    mdavlee
    Square ports for the intake and transfers. I wish all the old race saws stuff wasn't gone. Good pictures of port shapes and stuff like that from way back. I like those bridge ports you put in that 64 cylinder.
    concretegrazer and clemsonfor like this.
  10. Mastermind
    Mastermind
    Tennessee
    HF has a Foredom knock off that's pretty good. The handpieces suck.......but the Foredom handpieces fit.
  11. Mastermind
    Mastermind
    Tennessee
    Just a little extra transfer area.......and it aids in directing the flow. I do that on most two port engines.
    GRIZ, MasterMech, HoneyFuzz and 2 others like this.
  12. mdavlee
    mdavlee
    I was digging for finger port pictures but I can't find any.
  13. Mastermind
    Mastermind
    Tennessee
    Here you go.......
    Finger ported 064.
    $ooline, GRIZ, concretegrazer and 5 others like this.
  14. Mastermind
    Mastermind
    Tennessee
  15. Mastermind
    Mastermind
    Tennessee
  16. lukem
    How does a finger port work?
    GRIZ likes this.
  17. Mastermind
    Mastermind
    Tennessee
    It's just a extra transfer port.
    GRIZ, clemsonfor, HoneyFuzz and 2 others like this.
  18. mdavlee
    mdavlee
    I have some pictures of 288 cylinders on my computer. I have 2 46 cylinders to port soon and I may do a set of fingers in one.
    clemsonfor and Chvymn99 like this.
  19. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Im learning a ton here. Been wanting to see some finger ports..
    Hey Randy.... You da man !
    $ooline, GRIZ, clemsonfor and 4 others like this.
  20. Mastermind
    Mastermind
    Tennessee
    No, I ain't.......
    But I have friends that are.......and I pay attention.
    $ooline, GRIZ, JC@ATL and 7 others like this.
