Never burned aspen
Discussion in 'Everything Else (off topic)' started by TurboDiesel, Apr 24, 2021.
  1. TurboDiesel
    The BTU gods offered up a nice size bigtooth aspen, (popple, poplar).
    Dropped on one of my wheeler paths so not just easy pickins but i had to cut it up and move it anyway. So threw some on the wagon and took it right to the log yard and split it. Splits easy, kinda sweet smelling maybe. Keeping it separate for campfire wood.
    Pics in a bit.
  2. Eric VW
    You mean “God, ” right? :salute:
    I bet it does great as shoulder wood. :fire:
  3. TurboDiesel
    yes:emb:
    There are about ten or so kinds of pine that rank higher on the btu charts...even willow is higher.
    Ranks same as basswood, 13.7mbtu and 2210# per cord. Should dry in 6 months.
  4. Eric Wanderweg
    The bigtooth Aspen I burned this past winter was better than burning pine IMO. It burned very hot and very clean. I won’t pass on it again so long as it’s solid. It does seem to to get punky relatively fast if left on the ground.
  5. Horkn
    Yes, but willow doesn't split easily like poplar, it also does not season like poplar in a summer.
    You'll like it.
  6. TurboDiesel
    this one just uprooted last week. its solid and fresh. catkins growing on top.
  7. TurboDiesel
    I probably shoulda made at least one bowl blank from it.
  8. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Have turned down aspen too....but am beginning to collect some. Perhaps better than pine...not in btu's, but seasoning and lack of resin....
    Sca
  9. Softwood
    Softwood
    Central WI
    Yep. I burn a lot of Popple. It works great to heat the house up fast. I get a lot of it here that grows so big and then just tips over, usually about only the top half of the tree is good after they get that big, the rest is punk. I surely wouldn't pass it up if you have the room for it.
  10. bushpilot
    bushpilot
    Eastern Washington
    Aspen burns fine, similar in BTUs as some pines.
    I'm surprised you said it smelled sweet, I always find it quite stinky when split, until dried. Keep it off the ground, otherwise it rots quick.
  11. TurboDiesel
    Nice and straight. No branches. Easy to split. stacks straight.
    Camping wood or shoulder wood
  12. Horkn
    I'm not a fan of the smell of freshly cut/ split Aspen/ poplar either. But both my wife and I love the smell of elm. Everyone's nose is different.
  13. Backwoods Savage
    Over the years I've burned a goodly amount of aspen because years ago I did not always have my own trees to cut. Neighbors never minded if I took popple, especially if it was about to fall over. It really is not bad to burn in daytime if someone is able to keep the fire going but that is not so good at night.
  14. tree killer
    tree killer
    Central me
    Some places to the north it is one of the better woods. It’s all about where you live.
  15. hovlandhomestead
    hovlandhomestead
    MN
    We have a lot of it on our land. I cut, spit, stack and cover about a cord each spring before it comes out of dormancy, and it is ready to burn during grouse and deer camps by fall. It is great for shoulder seasons, and doesn't heat the guys out of the loft at night if we make a fire in the morning and one fire at night to keep the cabin comfortable.
    At home we burn some during the day if we are home to tend the stove. It heat the house just fine in the dead of winter if you keep a nice fire going.
  16. OldJack
    OldJack
    Saskatchewan, Canada
    Poplar - Quaking Aspen was about all the pioneers had for firewood here on the Southern Prairies. I cut enough with an axe when I was a teenager although oil and coal were our main sources of heat by the time I came along
  17. tree killer
    tree killer
    Central me
    I have some friends in Meadow Lake that own a guide service. I’ve gone out a few times, well because it was free, and other than the random white birch or fir and spruce poplar is it.
    OldJack and TurboDiesel like this.
