Which side should I use for this table?
Discussion in 'The DIY Room' started by grandgourmand, Apr 13, 2021.
  1. grandgourmand
    grandgourmand
    Ontario
    I sliced a big cookie from an ash round that was in my garage for four years.
    I just got a hand planer to smooth out the chainsaw marks and grooves. Still learning to use the planer...so no judgment!!
    I plan on belt sander next, then orbital. And finish with something (suggestions?). I don’t want to use epoxy because I want more matte finish.
    Side 1. It was exposed for four years. Figure it’s done cracking. But the cracks have chips that have me concerned. I will fill up with wood putty but not sure if the chips will dislodge or whatever.
    Side 2...looks pretty good. My main concern is that since it wasn’t exposed it’s got more cracking to do.
  2. Eric VW
    You can always fill/seal with epoxy and then final coat with a matte finish.
    That’s gonna look awesome when yer done.
    Legs up under it for a table?
  3. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    My wife has thinned oil based poly and filled holes. Let it dry. Sand. Repeat until hole is filled.
    Then do 2 or 3 thin coats with light sanding between coats.
    The imperfections are part of the natural look of the wood.
  4. grandgourmand
    grandgourmand
    Ontario
    thanks for the tip. I need to look into how to finish epoxy
    as far as the legs...yeah I figured under would be better. :smoke:
  5. grandgourmand
    grandgourmand
    Ontario
    How did she thin it?
    Chazsbetterhalf and Eric VW like this.
  6. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Oil based Poly, use a little mineral spirits. Makes it soak in to the cracks. Takes some time cause ya gotta let it dry between coats, but it looks good. She used it on old cracked picture frames.
  7. eatonpcat
    That's some solid advice for making a table right there!!! :p
  8. Semipro
    Semipro
    SW Virginia
    Check out this countertop on This Old House. They filled the cracks and other imperfections with epoxy and then used a different matte finish over everything. I think it looks great.
    The countertop is shown at time 9:00.
  9. Eric VW
    Why I oughta...:whistle::rofl: :lol:
    TBT, I forgot about the thread title when I typed my response. So there, I’ve admitted it.
    :wacky:
  10. Eric VW
    See reason ^^^
    Pre-senile moment, what else can I say?!
    :loco: :crazy: :BrianK: :D
  11. Canadian border VT
    Funniest thing I have seen today!!
  12. Eric VW
    You’re both reported. :rofl: :lol::rofl: :lol::rofl: :lol:
  13. Canadian border VT
    Hey eatonpcat i feel honored to be in this group!
    :rofl: :lol::salute::handshake:
  14. Eric VW
    You should, you crotchety ol’ curmudgeon.
    :wacky:
  15. Eric VW
    I sincerely hope you know I was joking.
    :handshake:
    Or was I?
    :rofl: :lol: :whistle:
    :eek:
    I was kidding. :)
  16. Canadian border VT
  17. lukem
    Get some table top epoxy. It will fill and seal in one step. You will have to tape off the bottom to keep it from leaking out of those checks/cracks.
    Go after it with some 40 then 60 grit on the belt sander, then 80, 120 on orbital. No need to go more than that if using epoxy finish for that imperfect piece of wood.
  18. brenndatomu
    You can't get anything past that Eric VW ...:D
  19. eatonpcat
    Yep, he is sharp as a bowling ball!! ;)
  20. Eric VW
    I got something in the works for when y’all flop in to the sugar shack...
    :whistle:
    :sherlock:
    :binoculars:
